My room easily hits 25*C all through the summer, I would like to add some more fans to my case to hopefully lower my temps.
My specs are
Q6600 @ 2.4Ghz cooled with Tuniq Tower 120
8800GTS Stock cooler
MSI P6N SLI Platinum
2GB corsair XMS2 PC6400
OCZ 600W Game Xtreme
Gigabyte 3D aurora case
ATM I have 1 120mm intake fan at the front, 2 120mm exhausts at the back and my PSU also exhausts air from the case. I was thinking of putting some fans on the side panel mesh window to suck the hot air out from beneath the GFX card and another above the GFX card to ram air onto the motherboard and into the CPU fan. is this going to help? what else would you suggest? are there any cheap ways to reduce ambient temperatures? (cant afford air con)
Thanks to everyone who replies
My specs are
