This is a new system build. First thing i did was remove the crazycool backplate and install my zalman. I was a little concerned about the acorn nuts used to hold the silent pipe setup on the NB. The spring loaded screws only tighten so far into the nuts so im not sure i am getting good contact there. My "system" temperature as reported in bios and with everest is low 50's at idle and low 60's after some gaming. This seems way to high to me. Cpu temps are nice at low 30's idle, low 40's load.
My old asus board always stayed at the mid 30's range idle and load. I sent Gigabyte an e-mail but no reply yet. Any suggestions are apprecited, Thanks
P.S., Is the system temp on these boards the temperature of the north bridge, or is it just a reading of the whole board in general?
