Hi, I just inherited a P4 3GHz PC with 512Mb RAM, WinXP Pro, onboard video, audio, and ethernet. I'm not sure of the motherboard brand and chipset because I just haven't looked yet. Here's the problem. The computer will get passed the post and the windows splash screen, but will stop as windows attempts to load at the blue "Welcome" screen. I say that it stops because it doesn't die, shut off, or reboot. The monitor goes black saying there is no signal, but the computer remains powered up. Even though the computer remains powered on, it isn't processing anything or "alive". Normally I would just hold the power button in until the pc shut off, however that doesn't work when the computer is in this suspended state.
So basically I'm not entirely sure if the problem is the motherboard, cpu, power supply, or RAM. Common sense says the power supply, but with the way the computer remains powered up I'm not sure. Is it possible for the power supply to spit out enough power for the fans and lights to remain powered, but not anything else? and if so then why does this only happen when I get into windows? Could it be the onboard video card? but then again why does it only happen when I get into windows? Any help is appreciated. For all I know it could be software related and I just need to format and reinstall. Thanks.
