Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > What is the best PSU for my System...One diddnt work
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - What is the best PSU for my System...One diddnt work
I am trying to purchase a PSU that will work in my system preferably under 150...around there...and i've already had one that diddnt want to compromise with me. Please help me out here...the one i tried is the link below... thx again. Also...im trying to look for one with modular cabling and preferably only a 4pin CPU 12V not an 8pin that splits.
One already tried - http://www.newegg.com/Product/Prod [...] 6817148028
This is My System...
Raidmax Smilodon Case
20X DVD+-R Burner IDE
320GB SataII
500GB SataII
4GB DDR2 800
3.0GHz AMD Athlon X2 Socket AM2 With Stock Heatsink and Fan
MSI K9A Platinum Mobo with Crossfire Support
Sapphire X1950 Pro (512Mb)
ATI TV Wonder 550
PCMCIA to PCI Adaptor
22" Widescreen ACER LCD Monitor
Saitek Eclipse 2 Lighted Keyboard
Logitech G5 Laser Mouse
Sponsored Links
First run the PSU calculator to verify your load. Run it as is, and with the additional components that you might be adding i.e., additional graphics card etc.
Edit: Be careful to only set single processor even thought it is a dual core because it is only one socket.
http://www.extreme.outervision.com/psucalculator.jsp
I just ordered this PS it is as solid as a rock and on sale 25% off. It is a little longer, so be sure it will fit your case.
Newegg.com - PC Power & Cooling Silencer 610 EPS12V EPS12V 610W Continuous @ 40°C Power Supply 100 - 240 V UL, cUL, CE, CB, TUV - Retail
http://www.newegg.com/Product/Prod [...] 6817703005
Message edited by Zorg on 07-31-2007 at 08:31:48 AM
Reply to Zorg
hey man, thanks i ran that calculator and it says i need at least a 500W between the 12V...i checked out that PSU u got but i have an ATX board not EPS and i was lookin for something with modular cabling...but thanks for the suggestion.
Reply to brock129
I just got an Antec NEOhe 550 that has module cabling. This is the 500w but for an extra $17 I was able to get the 550
http://www.newegg.com/Product/Prod [...] 6817103940
Reply to g-paw
The Corsair 520 is very capable and made by Seasonic! And Modular.
http://www.newegg.com/Product/Prod [...] 6817139001
Message edited by doglips on 08-01-2007 at 02:25:47 AM
Reply to doglips
Agreed, either the Antec NeoHE series, or the Corsair 520 will work well with the system listed by OP.
------------------------------ I suffer from A.D.O.S.
Attention Deficit..... OOOOOOH!!! SHINY!!!
+5 Victim
Reply to Groveling_Wyrm
EPS is a power supply specification. That power supply is for ATX motherboards and, at that price, it is the only one to buy. PCpower and cooling specifically does not make power supplies with modular cables due to the potential for resistance in the connections. They also use heavier gauge wire. read their PS myths page. If you can't see the value, then good luck.
http://www.pcpower.com/technology/myths/
Reply to Zorg
There are 1132 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
