Tom's Hardware Forums » Motherboards & Memory » General Motherboard » nForce compatibility / fire wall / 2.0v ram
Add a reply
 Word :   Username :
Bottom
Author
 Thread : nForce compatibility / fire wall / 2.0v ram
Profile: stranger
More Information
I already bought my hyper x ram which is 2.0v and today before purchasing my board i relized the board i want (asus m2n e) has an issue with ram, it only accepts 1.95v per reviews. WHICH ASUS AM2 SOCKET BOARD can i buy that supports 2.0v i wont be running sli or overclocking, so i wont be needing that insane asus striker board. any suggestions?
also is it true these n force chipsets have som kind of file thats a firewall and wont let torrents download
Related Pr oduct
Profile: member
More Information
http://www.newegg.com/Product/Prod [...] 6813131013
I know you won't being using the SLI, but it's a good board to invest in and will put you where you need to go.
I don't believe nforce boards do that, no.
Message edited by localcpugu y on 08-09-2007 at 06:25:29 PM
Thermaltake Armor Series Case - ASUS P5K Delux Wi-Fi Motherboard - Intel Q6600 2x4MB Cache 2.4GHz....@ 3.6GHz - 4GB G.Skill PC-6400@1125MHz 5-5-5-12 - EVGA GeForce 8800GTX - 2x 150GB Western Digital Raptor X (RAID-0) - 40" 1080p Samsung LCD.
Profile: stranger
More Information
I have an nforce 4 and it does have a firewall in the drivers ONLY if you choose to install it and it's just like a normal firewall. Doesn't block unless you want it to so no worries. nforce is great.
Profile: stranger
More Information
Ty advocate.
hey localcpuguy that was my 1st choice and i was going to get it for sure until i saw the m2n e its basicly the same board without all the sli stuff, but are they both picky with ram, what if the m2n sli deluxe also only supports maximum of 1.95 v
Add a reply
Google Ads
