Hi, I need help for a build that will be use to browse on the net and office stuff. There will be no games played on that PC.
I'm looking for quality parts and would like room for upgrade in the future if possible. It is for my parents, they doesn't change PC often. Also, Win XP will be the OS but will probably update to Vista in the future.
I was thinking about building it around an Intel E6300.
Here's what I need
-cpu
-motherboard
-ram
-maybe a video card under 100$
The board should have integrated audio and lan of course but I think that's standard now. Also, I would like a good stable board (like an Asus) cause my last one was an ECS I had trouble with it to retain bios settings.
There will be no OC and I don't need SLI.
thanks
Here's what I need
-cpu
-motherboard
-ram
thanks
