Comp, thought I would post results and a couple of notes on the calibration process.
System;
Gigabyte GA-G33M-DS2R
Intel Core 2 Duo E6320, 1.86 GHz, 4MB L2 Cache
Intel stock cpu hsf
Corsair xms2, 1 GB DDR2 Twin 2X, 6400 (800MHz)
Onboard video
Zalman Tech Co., Ltd ZM - 600HP Power Supplies ZMP600-HP
LIAN LI PC-A01B Black Aluminum MicroATX Mini Tower Computer Case
Part 1
Set bios according to instructions with the following exceptions;
■CPU Fan = did not know how to set to Max. the only options in the bios were for Auto, Legacy, or Disabled so I left this on auto (it gave a higher rpm vs. legacy at about 930rpm on an Intel stock cooler).
■PECI = no option available
■Software process = again, did not appear as a bios option but disabled those processes running in the background, through Vista (i.e. anti-virus software)
■Speedstep = did not see an option for this with this bios
Part 2
Ambient temp = 24.1c
Bios cpu temp = 29c
Bios system temp = 37c
Speedfan cpu temp = 25c
Offset made = +1c (Ambient +2c = 26c)
Note: upon intial start of Speedfan, cpu usage was running around 50%. Waited a minute or two until for this to settle back down to something less than 2% before taking any readings.
Part 3
cpu 1 = 38 hex, 56 decimal
cpu 2 = 38 hex, 56 decimal
(used CPUID to look at both cpu 1 and cpu 2 - drop-down box in upper right corner)
Stepping = B2 which is a Tjunction max of 85c
Tjunction max - CPUID decimal = 29c Tjunction
Part 4
Tcase (corrected offset) = 26c
Tcase + 12c = 38c
Speedfan core 0 = 30c
Speedfan core 1 = 29c
Offset made core 0 = 38c -30c = +8c
Offset made core 1 = 38c - 29c = +9c
Part 5
All bios settings restored to stock except left C1E disabled, and Vcore only increased to 1.285
TAT 100% load on both cores for 10 minutes
Speedfan results at 100% load
cpu = 48c
core 0 = 64c
core 1 = 63c
(for reference TAT was reading cores at 55c, and 52c)
Check: cpu of 48c + 15c = 63c which is +/-3c of core readings.
Results (final speedfan readings after closing case and settings back to stock levels)
Tcase = 33c idle, 48c Load
Tjunctions = 46c idle, 64c Load
The guide was very easy to follow with great explanations. The only two (minor) comments I have would be to note that Speedfan readings during the Tcase calibration should be made only when cpu usage is below 2% (assuming this is correct). The other would be to indicate in part 4 that the Tcase variable should be the value in which the offset was already applied (ambient +2c), again, assuming this is correct. These are really minor but thought it would be helpful for noobs like me.
I have two other systems I built this year and will now be going back to perform this calibration on each. I would appreciate if you could let me know if I did this correctly.
Thanks and Very Nicely Done!!
