Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Dual monitor question...thoughts?
Forum Graphic & Displays : Graphics Cards - Dual monitor question...thoughts?
Hey guys,
I'll be building a mid- to high-end gaming machine soon, and i'm curious about your opinions on something. Here's a quick overview of what i'm looking at:
GIGABYTE GA-M57SLI-S4 Socket AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
AMD Athlon 64 x2 5200 Windsor
2GB RAM
8800 GTS 320MB
Thermaltake 500w PSU
etc, etc.
First, any general comments on the build itself? I'm only getting the SLI for upgradability later.
My main question is this though:
Would you guys get a mobo with onboard video to handle a second monitor? i'm running dual 19-inch lcds now with just a 7600gs, and games run alright, but i'm really not sure how much the second monitor affects games.
if you would go with onboard viideo, any recommendation on a mobo <$120? sli isn't a definite requirement...for that matter, anybody know how well the 8800gts performs in sli compared to a single 640 or the gtx?
thanks all!
Sponsored Links
That is very similar to my question. I have an Intel DG965WH mb with GMA X3000 on board graphics and Windows XPsp2. Can I add a single video card and support 2 monitors?
TIA
------------------------------ Dogbarx
Reply to dogbarx
- 0 +
http://www.tomshardware.com/forum/ [...] onfig=toms hardwareus.inc&cat=33&post=244145&page=1&p=1&subcat=208& sondage=0&owntopic=0&new=0
Link to VGA charts, will help determine which 8800 to get if you are going that route.
As far as SLI performance charts, I'm at a loss. In regards to dogbarx's question,
Yes you can buy a videocard and run dual monitors with your onboard video. Be sure
to see what bus types your motherboard has before you purchase one though.
------------------------------ Q6600 3.0ghz, 4gig DDR2 800, DS3L 430 Thermaltake
Reply to Pesh
TIA
You could but most mid-range or better cards will have dual-outputs and perform better anyway.
Reply to fredgiblet
hahaha
------------------------------ AMD X2 6000+ @3.2Ghz | Asus crosshair | 4gb corsair xms ddr2 800 | BFG 8800GTS (g92)x2 SLI 805/1080 | SoundMax HD | (160gb)x2 sata in raid 0 | 500 gb sata | Lian-Li PC-6070 | antec 850W PSU | thermaltake water cooling | Vista 64bit | LG 24" | Logitech 5.1
Reply to ryanthesav
There are 944 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
