Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > new system - e6850/ultra120 extr/antec nine hundred - 47C load at stck
Forum Overclocking : Cooler and Heatsinks - new system - e6850/ultra120 extr/antec nine hundred - 47C load at stck
So i grappled with whether or not to setup my new system with water or go with great air cooling. I chose the latter after a lot of internal debate.
I put it all together last night, and lapped both my ultra 120 extreme and e6850 ... here's the setup:
e6850
ga-p35c-ds3r
8800gts 320
2gb crucial ballistix with d9 modules
ocz 700 watt gamestream powersupply
antec nine hundred case
I'm still warming the system up so i'm running 9x333. let me explain the cooling setup - i've got two 120 mm in the front of the case running full speed (rated 70 cfm each). I have a 120mm running six inches behind by top 120mm intake creating an 'air duct' right to the video card running full speed (rated 90cfm). the ultra120 extreme has a 120mm fan pushing air through the fins (70 cfm rated), there is an exhaust 120mm fan 2 inches from the back of the ultra120 extreme mounted to the case (110 cfm). the top of the case has a 200mm as an exhaut (rated 140cfm). the power supply is mounted on the bottom of the case with fan sucking air down and out.
The air flow is INCREDIBLE ... between the ultra120 extreme and the exhaust fan on the case i actually feel pressure that is hard to resist when i put my hand between the two.
thermal compound is arctic silver 5 ceramique.
So here's my issue. I'm using coretemp to measure. load with prime running maximum heat stress it's at 44C on one core and 47C on the other. This is at stock 9x333 and vdroop from 1.3 down to 1.264v when stressing. My idle temperatures hover between 28C on one core and 26C on the other core. I'm quite concerned.
Some reviews of ultra 120 extremes say that people have load temps in the mid 30s! did I do something wrong? perhaps I lapped unevenly? maybe those other people are measuring temp with speedfan instead of coretemp? maybe my system still needs to settle in? i have all these fans running on high and it's really loud - i knew this was going to be the case - but i thought i'd have cooler temps than these.
Message edited by bobkat on 09-01-2007 at 04:01:07 PM
Sponsored Links
http://www.techpowerup.com/downloads/392/mirrors.php
Try using this see if ur temps are any different
------------------------------ E6750 OC'd to 3.2GHZ
2GB Corsair XMS2, 850 4-4-4-12
Gigabyte GA-P35C-DS3R
BFG 8800 GTX OC
Reply to Charnondall
Hrm I thought TAT gave incorrect temps for c2d and was developed for pentium M single core chips.
with TAT my temps are on load 34 and 32 C while core temp says 49C and 47C (the day got hotter) ambient temp is now 23C.
which to believe?
Message edited by bobkat on 09-01-2007 at 09:35:33 PM
Reply to bobkat
Update:
I'm set to 3.8ghz (422x9) and 1.475 vcore in bios and speedfan/cpuz are showing drop to 1.41-1.42 while stressing
temps in core temp are now 33 idle and 56-58 stress
Reply to bobkat
That is NOT for C2D chips. Bobkat is right. Use coretemp or speedfan (speed fan requires you to add 15*C to the temp b/c its not configured right, I.E. 30*C in speedfan = 45*C in the real world).
Bobkat, thats a good OC. What did you do to fix your temps? The heatsink wasn't properly seated?
Reply to Synthetickiller
I didn't do anything actually my temps were as follows:
stock: idle 26-28 and stress 44-46
3.8ghz: idle 35-38 and stress 56-59
ambient temperature today is 25C
do these seem right for the setup i've described above?
Reply to bobkat
Yikes didnt know that, just tested mine with coretemp at idle on 3.4 they are at 25-29 and at load 54-55. Im using a 120 ultra as my heatsink
BFG 8800 GTX OC
yea similar for me - between 3.0 and 3.6 i idle around 26-28 and load 44-46 ... no difference really but i can undervolt and get 3.6 ... to get 3.7 however undervolting does not work i have to run 1.375v
Reply to bobkat
bobkat,i think you have a good OC, mine at 3.7ghz using core temp 95.04 idle 34-36C, load(orthos/prime) 46-50C, bt the difference between us is with the voltage, i have to pushed it to 1.55 enable to get a stable system.
------------------------------ e6750@3.7ghz 1.5v,ds3r, ultra 120 extreme,2X1gb geil ddr2 800
3d aurora full,x1950 pro 512/256b, 320 &160 seagate
Reply to omzhky75
WOW 46-50C on load with PRIME!?!?!
what kind of cooling?
at 3.8ghz my ultra 120 extreme lapped, chip lapped, antec nine hundred, 200 mm fan, 5x 120 mm fans keep my chip at 57-61 with dual instance prime running.
maybe i need to re-seat my ultra 120 extreme?
Message edited by bobkat on 09-03-2007 at 07:04:24 AM
Reply to bobkat
perhaps you should try reseating it,i used to have temp such as yours and didnt feel contented due to the writeups i red re ultra 120 extreme cooling ability.i put an extra thermal compound as packed with 120 xtreme,making sure it wouldnt profusely leaked out of the cpu top.my tt 120 extreme is also lapped to 600 grit but not the processor.nways, i think your temp is good enough considering you're 1 ghz OCing,i think.but should you want to lower it more try reseating and check surfaces of both.
Reply to omzhky75
so what exactly is involved in 'reseating' the ultra 120 ex? Do i have to completel remove the HSF assembly or do i just loosen the screws and shift the HSF around a bit and then tighten the screws back down?
Reply to bobkat
also,remember your temps are always gona be relative to your enviroment temps.ie in summer it average around 10degrees hotter,i loosen my overclock a bit..
------------------------------ Asus p5b
Dual core 6400@3.00Ghz with Zalman fatality fs-c77 fan
xfx 8800gts 320mb @900mhz/600mhz stock cooler
2Gig ddr 800 ram @ 760mhz
Reply to goldenboy
So i reseated my HSF and the results are not that different:
e6850 at 3.8ghz 1.475v set in bios 1.41v on load as per speedfan/cpuz
when ambient is 22C : idle is 33C : load is 57C
when ambient is 29C : idle is 39C : load is 64C
does this seem like the right temps for an antec nine hundred with all case fans running on high, the optional duct fan installed, a 110CFM silverstone fan at exhaust, e6850 lapped, ultra 120 extreme lapped? seems really high to me. any ideas?
Reply to bobkat
Here is my stuff and I have a question about TAT, core temp and speed fan
My temps seem to be roughly the same....
My specs
E6300 OC'd to 7x458 (3200) with a vcore of 1.2875 Lapped
Ultra 120 Extreme Lapped with a Scyth s flex
Chief tech case with 120mm fan in front, 80mm fan at side running at half speed for quiteness, 2 120mm fans for outtake, one in back one as a blow hole.
I am right now running Dual Prime 95's. Ambient temp is at least 76 degree in house, no more than 78 degrees ( have thermostat set at 76, but i am in a room that has 3 walls that is all windows...
Core temp says core 1=48c-50c
core 2=48c-50c
Tat says core 1=44c to 46c
core 2=44 to 46c
Speed fan pretty much agrees with core temp
Tat, core temp and speed fan all agree on idle, of 38-40c
Edit: My question, core temp when I set it to show tjunction, it shows 48c on idle and but when I start Dual Prime95's, it drops to 37-38c??????
Why?
Message edited by xringx on 09-07-2007 at 05:56:49 PM
------------------------------ Q6600@3.6(9x400)Lapped Abit IX38QuadGT,TRUE 120 Lapped,Vista Ultimate 64bit,Gigabyte HD 3870 OC'd to 860/2250 w/ Zalman Fan,4x2GB G.Skill PI-Black,CM690 w/ 5x140m 3x120m fans,Idle 28c load 42c-Corsair HX620w
Reply to xringx
now showing my tjunction at 35-37 on coretemp. TAT is 46-47 and speed fan is a solid 48c
Reply to xringx
I think my high temps were a function of ambient temperature, since the weather has cooled down now I have about 3 or 4 degrees cooler temps. I decided to go to 1.6v and 4.0ghz here's a screenshot. she lasts for about 10 mins in prime95 but i can game for hours.
http://img237.imageshack.us/img237/972/4ghzqb9.th.jpg
Message edited by bobkat on 09-12-2007 at 12:53:51 PM
Reply to bobkat
There are 1267 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
