I have an ASUS PC with a DVI-I output. 3 by 8 pins and a seperate set of 4 pins in the middle of which is a 'cross' that looks like it will take a 'slot' type of connection both vertical or horizontal - or maybe a row of pins, horizontal or vertical.
My Viewsonic monitor has a DVI-D connection: 3 by 8 pins and then a 'slot' that runs in the same direction of the 3 by 8 pins (i.e. along the length of the connector).
I went out to get a DVI cable and was told that there are many types - hence the above description.
From what I understand the DVI-I connector is 'multipurpose' analogue or digital (?).
As I want to run digital (I think there is a problem with my A/D converter on the mobo as the colours of text are 'strange' - from black to purple - even in the same word - and alternate lines clear and 'fuzzy') what cable do I buy?
Sorry for asking but the local PC suppliers are of no help.
Contacted Viewsonic locally but they don't stock DVI cables (!!!)
ASUS agent has 'dissappeared'.
Theres only one DVI standard, any home theater store like Circut City, Best Buy will have what you need. DVI or Digital Video Interface will do the job. Theres also HDMI which is backward compatable with DVI, HDMI caries both sound & HD video. You don't need the latter.
Message edited by systemlord on 08-09-2007 at 12:03:51 PM
------------------------------Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Reply to systemlord
Sorry, should have explained, I'm stuck out in 'Sunny Kuwait' at present.
Present T° is 47°C (117°F). So you can see why after 1 1/2 hours slog on foot I decided to revert to this forum!
I don't know how you guys handle the heat, here in Southern CAL it is 88%F that must seem cool to you. Theres nothing local out there? Take care of yourself and keep up the great work you guys are doing.
Reply to systemlord
