Components ------------ Antec Sonata III Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply $149.95 ASUS P5B Deluxe LGA 775 Intel P965 Express ATX Intel Motherboard $176.99 EVGA 320-P2-N811-AR GeForce 8800GTS 320MB GDDR3 PCI Express x16 HDCP Video Card $279.99 Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails $99.99 Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 $309.99 2 CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) $230.00 2 Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive $219.98 Subtotal: $1,466.89
Here are my questions: - Is there anything that I miss from the component list? I don't have fan and heat sink. Can you recommend a good heat sink for this system. - Is the 500W PSU enough for the system? - Will the motherboard and/or Windows XP recognize all of the 4GB memory? I am planning to use the system for video editing. - Is there a better component (MB, GPU, case, or PSU) that you would recommend? I am going with Q6600. Everything else is opened for me.
Thanks in advance for your feedback!
Message edited by netstrader on 08-03-2007 at 11:01:36 AM
hey, you might want to think about getting the GIGABYTE GA-P35-DS3R
motherboard, it's much better and much more future proof. 500W would be enough but get a Corsair 520W instead of the antec. I sent you a PM by the way about your system.
If you wanna talk about it msg me at AIM/Yahoo Maximus9102
