This is the board that im strongly leaning towards ( EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail). Being my first build and all, i have noticed that you either get an sli board that can handle two pcie x16 slots or you can get a p35 board that can handle ddr2 and ddr3 but only one x16 slot. Are there boards that can do sli and also ddr3 or have i just missed something? Also the build includes an e6750. Will there be a problem fitting a Zalman 9700 with this board? Also how do i find out if the board has the right 3pin or 4pin connector for the cpu cooler as i can't seem to find that in the specs? Finally, will a 700w psu be enough to handle 2 8800 gts 640mb?
Here are all the components, opinions on compatibilty and anything else would be greatly appreciated
* GIGABYTE 3D Aurora 570 GZ-FA1CA-ASB Black 1.0 mm Aluminum body ATX Full Tower Computer Case - Retail
* EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
* EVGA 640-P2-N821-AR GeForce 8800GTS 640MB GDDR3 PCI Express x16 HDCP Video Card - Retail
* OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply - Retail
* Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 Processor Model BX80557E6750 - Retail
* CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4D - Retail X2 (I will need vista 64bit to recognize 4 gigs of ram correct?
* Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
* ZALMAN 9700 LED 110mm 2 Ball CPU Cooler - Retail
thanks in advance
thanks in advance
