Hi, I picked up a Freezer 7 Pro today on a whim and wondered what direction it needs to face when I fit it?
The instructions state 'Align the Freezer in a standard ATX case in such a way that the fan blows the hot air to the back. Use there a case fan to remove the hot air.'
I have an Antec Nine Hundred case which has a 12cm fan on the rear and a 20cm top fan. The instructions seem to suggest that I should point the Freezer fan in the opposite direction of the rear 12 cm fan (i.e. facing the 5.25" bays), is that right? Would I see any improvement pointing it in any other direction (e.g. pointing the fan towards the bottom so the 20cm case fan draws the heat away instead?) I am a complete noob to cooling systems.
Second quick question, is that along with the cooler I picked up another 12cm fan to mount in my case as there is room for one on the side window. What way do I need to mount this? (i.e. backwards or forwards?). It's currently mounted in the direction shown in the picture below of me holding it (forwards?), as the other fans are. However reading about, am I right in saying I want some fans to be positioned the other way (backwards?)... so some draw in air whilst others can expell it back out of the case? Or am I talking nonsense?
Any help much appreciated.
Rig:
E6300 1.66Ghz (OC @ 3.ghz)
Gigabyte 965P-DS3
2GB Patriot DDRII 6400
Leadtek 7950GT OC
80GB x 2 (Raid 0) (XP)
400GB x 2
500GB x 2
40GB (Linux)
Sony NEC DVD-RW
Medion DVB-T 100 Tuner
Hiper Type R 580W Modular PSU
Antec Nine Hundred
AC Freezer 7 Pro
Inside:
Freezer 7 Pro box:
Side fan:
Side fan - fitted the right way?
Rig:
Gigabyte 965P-DS3
Leadtek 7950GT OC
400GB x 2
500GB x 2
40GB (Linux)
Sony NEC DVD-RW
Antec Nine Hundred
AC Freezer 7 Pro
Inside:
Freezer 7 Pro box:
Side fan:
