New System Build plz help
Last response: in Systems
Hi there,
I really need to replace my old pc and want to buy something new.
I would like to build a pc with good overclocking potential, and want to play the latest games.
Can anyone tell me if this is possible using the parts below:
(the mobo supports sli and has PCIe X16 in single mode and X16/X4 in Crossfire, would it still make a lot of difference if i bought a second 8800 GTX next year when the prices are a bit lower?)
1x GigaByte GA-P35-DQ6, P35 (ATX, Sound, LAN, SATA II, RAID, 1394)
1x Intel Core 2 Duo E6750
1x Club3D Geforce 8800 GTX 768MB DDR3 (PCI-e, 2x DVI) CGNX-X8868
1x Corsair QUAD2X4096-6400C5DHX
1x Tagan TG700-U25
2x Samsung SpinPoint T166, 500GB (7200rpm, SATA II, 16MB, NCQ)
1x Samsung Syncmaster 226BW (22", wide, 2ms (GtoG), D-Sub/DVI-D...
1x Scythe Infinity SCINF-1000 (Socket 478/775/754/939/940/AM2)
Thanks for your help!
More about : system build plz
Ask the community
