I recently installed Speedfan to check my temperatures.
It says my fan is at 450000rpm so I am assuming the zalman controller is interfering with that.
Core temps look good 27/26 idle, load temps 45/43
But the first reading which looks like northbridge is reading 51 idle and 65 load.
Is that normal for the P35?
Speedfan 4.32 does not have my motherboard listed, could that be effecting my results?
Is there a better temperature monitor for my P35-DS3R I should try?
Does anyone make aftermarket heatsinks for the P35 yet? Low enough to fit under my 7700 Zalman?
