So, just put together my new system. I'll list the components and then state the problem after.
Athlon 4400+ AM2 Brisbane
2 GB OCZ Vista Upgrade DDR-800 (1 gb x 2)
Antec Sonata II case with Smartpower 2.0 450 ps
120 GB WD hard disk, IDE
300 GB Maxtor HD, IDE
Soundblaster Audigy 2 ZS
PNY 7600 GT
Two LCD monitors (Acer 19" and BENQ 20" widescreen) using extend desktop both through DVI connections
Here's the problem:
Certain games I'm running to test it out start skipping as a play. Not immediately but, say, about 10 minutes into playing. Everything just gets really jumpy and altering graphic settings has no effect (I tried lowering to the minimum resolution and it did the same thing). I ran a temperature monitor on the CPU and it never got hotter than 30 C and I ran a voltage monitor on the PS and didn't see any fluctuations. Any ideas? I'm REALLY hoping it's not the CPU because I bought it long enough ago that it's out of warranty (OEM). THanks!
PNY 7600 GT
Here's the problem:
