Yes No
Ads
Tom's Hardware > Forum > Windows XP > Drivers > ATi high definition audio driver problem
Forum Windows XP : Drivers ATi high definition audio driver problem
Hello,
I downloaded this driver at driver robots suggestion to my PC which uses XP. After which I have no sound at all can you help?
Reply to spcc
You should always download your drivers from your manufacturer's website.
Try opening the device manager, and rolling back the audio driver.
------------------------------ CM HAF 932 / GIGABYTE GA-EP45T-DS3R / E8500 @ 3.75Ghz / 300GB Velociraptor / 4G DDR3 OCZ Reaper 1333
Saphire 1G 4850
Simple and Free Guide to Removing Malware
Reply to aford10
Thank you I tried that but it did not work. Any other suggestions?
Reply to spcc
Was there a yellow ! on your audio device in the device manager?
Saphire 1G 4850
Reply to aford10
Ok, right click and uninstall the device. Then restart the PC.
What model computer or motherboard do you have?
Saphire 1G 4850
Reply to aford10
Not sure of mother board I am an amature but I have a DELL Vostro 420 computer
Reply to spcc
Once you've uninstalled the device and restarted, you can download the latest audio driver here.
http://support.us.dell.com/support [...] eid=271505
Saphire 1G 4850
Reply to aford10
As it is a Realtek Codec, you can download the latest driver from the Realtek Website itself.
http://www.realtek.com.tw/DOWNLOAD [...] Down=false
Hope this helps!
------------------------------ If you think this post was the most helpful, please remember to click on"SELECT AS BEST ANSWER"!
Reply to saran008
Happy to see it worked!
If you think this post was the most helpful, please remember to mark it as the best answer! :)
Reply to saran008
:lol: begger
Saphire 1G 4850
Reply to aford10
spcc wrote :
Thank you it helped
You're welcome
Saphire 1G 4850
Reply to aford10
spcc wrote :
Hello,
Get the Driver,from the motherboard manufactor,which i did and was the newest one,one i got from microsoft was dated 2001,one i got from asus,as my mobo is asus,is a 2010 release,actual date was end of 2009,which is 8 years difference,all i did,was follow the read me file,run setup,and it replaced the old driver i had,am now reading on overclocking/Tweaking features on this audio,already did my radeon hd 4200 which is on board,factory sets it at 500 mhz,but i upped the gpu and core to 775 mhz,Major difference,drivers are always first in this area,,then,theres always a way to over clock in a safe way,read read and read,memory,i didnt over clock,i have hyperX 8500 which im sure,kingston used 6400,and over clocked it too 8500 1066,had problems when i tired it,so set it at 533 mhz,and all auto,did well and i didnt over clock the cpu,well not yet,and always when doing the fsb,in memory,leave the HT on auto,or it will change the settings for the memory way too much,as it is my 3000mhz,amd Athlon II x 4 640 is now running at Core Speed 3150.3 MHz
thern backed off the memory,was running way too Hot so to speak,was @
here is the data,but WATCH it>>
Northbridge AMD 785G rev. 00
Southbridge AMD SB700 rev. 00
Memory Type DDR2
Memory Size 2048 MBytes
Channels Dual, (Unganged)
Memory Frequency 560.0 MHz (3:8)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 10
RAS# Precharge (tRP) 10
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 18
Command Rate (CR) 2T
Uncore Frequency 2100.2 MHz
Then the video as well
Primary Adapter
Graphics Card Manufacturer Powered by ATI
Graphics Chipset ATI Radeon HD 4200
Device ID 9710
Vendor 1002
Subsystem ID 83A2
Subsystem Vendor ID 1043
Graphics Bus Capability PCI
Maximum Bus Setting PCI
BIOS Version 010.094.001.010
BIOS Part Number 113-B43106-X04
BIOS Date 2009/02/18
Memory Size 700 MB
Memory Type HyperMemory
Core Clock in MHz 775 MHz
Memory Clock in MHz 533 MHz
And here you have it,safe sound,and Rocking,but the memory,BE VERY Careful,please,if it starts rebooting then,back off,let the auto function do its job,Good luck!
Reply to Timberwolf51
There are 2105 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Windows xp shut down scripts
By nhasian, 21 hours ago:
yes thats fine.
Best offers
Top experts
