Linksys BEFSR41 Problem ?
Forum General Networking : General Gateways, Routers and Firewalls - Linksys BEFSR41 Problem ?
Alright I own a SpeedStream 5100,
http://www.hal-pc.org/networking/modemlights/5100.jpg
Which is connected to my Linksys BEFSR41 (ver 4.3)
http://images.tigerdirect.com/skuimages/large/L48-2236.jpg
And connected to my router is my Xbox 360, and my PC. (Via Ethernet)
I'm going to try and narrow this down,
Say I have friend A, B, and C.
I can play with friend A just fine, no lag, no problems, etc.
But I cannot connect to friends B and C.
So we thought it was a minor problem,
And friend A, started a game, and invited C.
They were in the lobby, everything was cool.
Friend A invited me, and I couldn't connect.
So C leaves the game, and A reinvites me.
I join his lobby just fine, now A invites friend C.
Now C can't connect.
(Note: We tried this same thing, only by using B instead of C )
Now this is what I think is making it a router problem.
Ok so,
My friend tells me,
Have you opened your NAT?
I do so, then on my router status page, it says Connected,
As normally.
Then I attempt to log back on MSN, it will not let me, it's acting as if there is no internet connected.
Can't go on any webpage, nothing.
But I can access my Router Settings page, and on the Status page,
It says Connected.
I try logging into Xbox Live, and it's acting the same way.
(Note: My Computer has no internet problems like this, unless I disable NAT)
So I re-enable my NAT on my router, and disable all other security settings that could be blocking my connections with other friends.
And Still,
No Dice.
So this is my only option, I can't open my NAT due to me not able to do anything internet related, afterwards.
Thanks for reading, and help if you can!
Sponsored Links
have you installed ipx in all computers, you can do this in Local Area Connetions Properties.
Also I find if the server computer enable dmz host helps, last is use the port fowarding to open the recommanded port for that game.
Message edited by gomerpile on 05-26-2008 at 12:52:16 PM
------------------------------ WAITING FOR THE NEXT MOMENT TO STRIKE
Reply to gomerpile
well only one computer is on the router, soo it's just the PC, and my 360.
DMZ is infact enabled
and iunno whut IPX is
Reply to CherryCoke
IPX/SPX?
Client and server packet exchanges Needed for home Lan/Network gaming
Message edited by gomerpile on 05-26-2008 at 12:10:02 PM
Reply to gomerpile
I didn't find anything for IPX/SPX anywhere in my router settings.
Reply to CherryCoke
Forget IPX! Try connecting your PC directly to the SpeedStream and see if it works.
Grumpy
Reply to Grumpy9117
Works.
However 360 to Speedstream does not
Reply to CherryCoke
Did you power cycle the Speedstream after connecting the 360? Is the 360 set for DHCP?
Grumpy
Reply to Grumpy9117
I saw nothing of DHCP on 360 settings, wut you mean by power cycle ?
Iunno, haven't tried it.
Reply to CherryCoke
bump for great justice
Reply to CherryCoke
- 0 +
This is a common issue with all online gaming. There is no real solution for this and nothing the end user can do. This completely deals with the routes (BGP) over the internet. Does ISP A. Have the proper BGP (AS number) addresses to access ISP B.?
This is similar as to what happened a couple of years ago, when someone in India changed a BGP address and messed with youtube.
Can you ping your friends public IP address? Make sure he has ICMP turned on as well.
Cheers.
Reply to wigglz
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Linksys BEFSR41 Problem ?
There are 1150 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
