I'm looking to build two new systems, these will be my first system builds from scratch. One system will be for my in-laws who will use it for general web browsing, general "office" tasks (word processing, a little Powerpoint, some spreadsheets), light photo editing and light DVD creation (using a Sony hd-based camcorder). The other system will be for my family and will do most of the above with the addition of some gaming (nothing too hard-core) and heavier video editing/DVD authoring.
I'm pretty comfortable choosing hard drives, DVD burners, keyboard/mouse, monitor and case, I think I've identified a decent processor (Intel Core 2 Duo E4400) but would like advice on motherboard, memory and (for my machine) video card. For memory, I figure I'll put in 2 GB of memory for both, what advantages do I get going for DDR2-800 versus DDR2-667? For motherboards, I want something that will be upgradeable in the future and am trying to decide between a P965 board versus a P35 board - why would I choose one over the other? Finally, for my in-law's machine I think the onboard graphics will be fine (they tend to use lower screen resolutions so icons, fonts, etc. will appear larger to them, there's little reason to worry about high-end graphics for them) but I do want to be able to do some gaming on my machine - what should I be looking for assuming I want to keep the costs down (gaming won't be the top priority for this machine, maybe my next build)? I won't be doing any overclocking for these machines.
Thanks for any help you guys can offer.
What are your budgets for each machine? This really determines what to recommend. Get the budget for each machine, would guess you're willing to spend more on yourself. Then cost the stuff you know that you want and subtract that from the total. Then list the parts you're undecided on and how much you have remaining. If your camcorders have firewire connections, it's best to get a board with onboard firewire but these generally have onboard video or SLI but given you'll only likely have 3 PCI slots no sense in taking one up with firewire. If you need an OS for each machine include that in your budget. You may want to consider XP, Vsta still has some compatibility issues, e.g., make sure you won't have problems with your video editing program. Regardless of what OS you decide on, get the OEM version. Would suggest you go to newegg.com and create a couple of Wish Lists for each machine, easy way to track costs. Depending on your budget, you may want to consider AMD, which is still less expensive than Intel, especially for your in laws. Couple of good referrences
http://www23.tomshardware.com/cpu.html
http://www.tomshardware.com /2007/08/06/the_best_gaming_video_cards_for_the_money/
The only real difference I anticipate between the two systems will be adding a graphics card to the system for my home, my in-laws will get by fine with the onboard graphics of whatever motherboard I pick (as I said, their graphics needs are pretty easy to meet). I'm not worried about firewire connectivity for any of the camcorders - my in-law's camcorder has a USB 2.0 interface, I'm currently using a DVD-based camcorder (I've got some older video stuff I recorded on a miniDV camcorder but I've transferred all that footage already).
I'd like to keep the cost of the motherboard under $150, ideally closer to $100. I'd also like to keep as many components similar between the two systems so if I get called for tech support (the downside of building them a system) I'll know exactly what I'm looking at. I'll stick with XP home for both systems as well.
I'm considering the following motherboards:
http://www.newegg.com/Product/Prod [...] 6813130095 (MSI P35 Neo-F)
http://www.newegg.com/Product/Prod [...] 6813130052 (MSI P965 Neo-F)
http://www.newegg.com/Product/Prod [...] 6813128057 (Gigabyte GA-P35-S3L)
http://www.newegg.com/Product/Prod [...] 6813128017 (Gigabyte GA-P965P-S3)
For my video card I'll probably go with a GeForce 7600 GS (best gaming value under $100), that seems like it will fit my needs.
The rest of my list:
http://www.newegg.com/Product/Prod [...] 6822145087 (Hitachi 250 GB SATA hard drive)
http://www.newegg.com/Product/Prod [...] 6811119080 (Cooler Master Centurian case with 380 W power supply).
I'll add whatever dual-layer DVD burner is cheapest at the time I'm buying (my experience is there's no good reason to spend more than necessary on the DVD burner, at roughly $30 it's not worth sweating the details too much). My in-laws will probably need a new keyboard and mouse, I'm not worried about those (nor upgrading their monitor from the current 15" CRT they have now).
Thanks for any help.
I would go with the GIGABYTE GA-P35-S3L because it's a newer chipset than the 965 and has 3 PCI slots. For onboard video would go with the MSI P35. One advantage of MSI is that it is really easy to update the onboard drivers and BIOS, can do the whole thing on line. Might want to consider something like this Antec, more expensive but better PSU or a Cool Master Centurion with something like an Antec, Enermax, or FSP Group PSU with at least 450w, 500 to 550w if it fits your budget.
http://www.newegg.com/Product/Prod [...] 6811129158
Neve r had a Hitachi drive so can't comment. I usually get Seagate. You might want to consider a smaller hard drive for the OS and programs and a 2nd larger for date, you don't have to worry about backing up data when the OS goes south. You can get an 80GB Seagate for less than $50. I recently got a Samsung 18x DVD burner and really like it, very quiet.
| Quote : I would go with the GIGABYTE GA-P35-S3L because it's a newer chipset than the 965 and has 3 PCI slots. For onboard video would go with the MSI P35. One advantage of MSI is that it is really easy to update the onboard drivers and BIOS, can do the whole thing on line. Might want to consider something like this Antec, more expensive but better PSU or a Cool Master Centurion with something like an Antec, Enermax, or FSP Group PSU with at least 450w, 500 to 550w if it fits your budget.
What would be the advantages to moving to a larger power supply? I can afford the delta in price but I'd like to understand what I'm getting for it.
| Quote : Neve r had a Hitachi drive so can't comment. I usually get Seagate. You might want to consider a smaller hard drive for the OS and programs and a 2nd larger for date, you don't have to worry about backing up data when the OS goes south. You can get an 80GB Seagate for less than $50. I recently got a Samsung 18x DVD burner and really like it, very quiet. |
I've thought about that approach, I'd probably get a cheap IDE drive as the OS drive (and get redundant SATA drives for data, either in a RAID 1 configuration or just running a backup from one drive to the other). Adds a little cost but I think the data protection would be worth it.
Given that most boards now only have one ATA connector, 2 devices, and there is really no price difference, I think you'd be better off getting a small SATA rather than ATA drive. In reading the various postings there seems to be a lot of problems associated with PSUs and sufficient power. While both Intel and AMD are working hard to reduce power consumption, and AMD seems to have the lead in this, the power demands for the system as a whole is increasing, no doubt in part because programs are doing more and demand more resources. While I haven't done a formal survey the consensus on this board seems to be that it's best to have at least a good 450w PSU. As I'm sure you're aware, even light DVD work requires a lot of resources for capturing and especially rendering and when you combine this with the demands of security programs, and the fact most of us are running multiple programs at the same time there is a cumulative increase. The companies I mentioned about, Antec, Enermax, or FSP Group, all make good PSUs. As for cases, the one thing I'd look for would be a 120mm fan because they are quieter. I have a couple of Antec Sonata II cases, which I really like because they are quiet and very easy to work with. They have recently been replaced by the Sonata III, which is a nice case with a good PSU but kind of pricey, between $130 and $140. I'm probably closer to your in laws age and I'm seriously considering an aluminum case the next time I buy one, which likely won't be for several years because they're lighter. But if they pretty much set up a computer and aren't often moving it or doing a lot of upgrades, this really isn't an issue. Weight is likely more of an issue for us old "geeks"
If you want a on board video get one with a dvi port or a low end video card the ram hit on of on board video is bad if you want to run vista and vga only is not good.
Processor ($65)
http://www.newegg.com/Product/Prod [...] 6819103068
Motherboa rd: ($80)
http://www.newegg.com/Product/Prod [...] 6813138081
Video card: ($160)
http://www.newegg.com/Product/Prod [...] 6814127284
PSU: ($55/$80 w/case combo)
http://www.newegg.com/Product/Prod [...] 6817182017
Ram: ($90)
http://www.newegg.com/Product/Prod [...] 6820231098
Hard drive: ($75)
http://www.newegg.com/Product/Prod [...] 6822136074
DVD ($30)
(Get a SATA drive! Not IDE)
You will not find a better performing build for under $600 (+OS). Will overclock to 2.5GHz easily. Runs oblivion fine with max settings, 1280x1024. Hell I figured it would take another year or two before anything under $600 could run oblivion at max settings!
| Quote : You will not find a better performing build for under $600 (+OS). Will overclock to 2.5GHz easily. Runs oblivion fine with max settings, 1280x1024. Hell I figured it would take another year or two before anything under $600 could run oblivion at max settings! |
Is this going to be a good build for video rendering/DVD authoring? I was under the impression that Intel chips are better for processor-intensive tasks such as video rendering. Also, if there's an IDE port on the motherboard what's the downside to an IDE DVD burner? I'm up in the air on this, using an IDE burner saves a SATA port for future hard drive expansion. Also, I don't have a need for a video card that will run Oblivion at max settings, I'd probably scale that down.
dude87 wrote :
This would handle video editing. I'm currently using a 939 X2 4200 for capturing, editing, and rendering/burning. No matter how you cut it capturing and rendering/burning takes a long time and shaving a few minutes off it really won't make a whole lot of difference. If you're capturing, you don't want to do anything that will throw the audio/video sync out of whack so you probably wouldn't want to do anything that was particularly resource intensive like playing games, on the other hand you want to be able to surf the net, listen to music, lighter stuff and the AMD X2 will handle that. Most of the time I render and burn over night although I've created mpg files from Adobe Premier Essential projects while surfing and listening to music. Right now if I were building for myself for video editing, which is the most intensive thing I do, I would go with E 6400 with 2GB of DDR2 800 RAM, and a P35 mobo. I currently have a 7600GT card but depending on the price if I were to get a new one would probably go with the 8600GT because it can handle DX 10 but again I don't game so the video card isn't that important. However, on a tighter budget I wouldn't hesitate to go with AMD. If I were building for someone else like you are for your in laws, I'd go with AMD AM2 X2 4200 or 4400 with the ASUS M2NPV-VM board, have a couple of these and they have a DVI connection and have been rock solid. As for the support you referred to in an earlier post, once the machine is up and running any problems will likely be software. If it is hardware, you're not likely to solve it over that phone anyway.
Okay, how would this system look for the in-laws:
http://www.newegg.com/Product/Prod [...] 6813131014 (Asus M2NPV-VM mobo)
http://www.newegg.com/Product/Prod [...] 6819103776 (AMD 4400)
http://www.newegg.com/Product/Prod [...] 6811129158 (Antec case recommended above)
http://www.newegg.com/Product/Prod [...] 6820220091 (2 GB Patriot DDR2 800 RAM, 2x1 GB modules)
http://www.newegg.com/Product/Prod [...] 6822145132 (Hitatchi 250 GB SATA hard drive)
http://www.newegg.com/Product/Prod [...] 6827136120 (LG SATA DVD burner)
This would be for my in-laws, no gaming (so no video card, I'll go with onboard).
Nice system, wish my kids were this generous
If you're not going with a smaller hard drive for the OS/programs, would partition the drive so they can put their data on a separate partition from the OS/programs. In addition, if you're installing any programs, e.g., word, photo, or video, I'd set the defaults for the data partition. You don't want to run into a situation where you have to do a clean install of Windows and worry about saving their data.
I'll probably add a small hard drive for OS as you suggest, although there will be a user-training issue to make sure they save all data files to the data drive
I'll probably go with an Intel P35-based system for myself.
| dude87 wrote : Okay, how would this system look for the in-laws:
nforce 7050 board for $10 less
http://www.newegg.com/Product/Prod [...] 6813157116
| dude87 wrote : I'll probably add a small hard drive for OS as you suggest, although there will be a user-training issue to make sure they save all data files to the data drive |
That's why I suggested that if you install the programs, create folders on the data drive and make them default, might make training easier. Can't understand why people have such a hard time figuring out how to save data to another drive or partition. Good friend of mine, bright guy with a couple of Master degrees, can't comprehend this. Drives me nutz when he calls with a problem and have to deal with backing up data. On the other hand, when ever we buy anything not related to computers that needs assembled or installed, my wife has to do it.
Guess that's why Division of Labor was invented.
There are 1448 identified and unidentified users. To see the list of identified users, Click here.
