Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-P35C-DS3R BIOS Flash problem
Forum Motherboards & Memory : Gigabyte - GA-P35C-DS3R BIOS Flash problem
When I flash my bios in Q-Flash to bios revsion F4g, it verifies that the flash successfully completes, but upon rebooting the computer keeps restarting with a bios auto-recovery message. The only way I can stop this is to remove the battery from the motherboard to clear the cmos, thats when it reverts back to the old F2 bios revision and boots fine thereafter. I've since downloaded the file again verifying that it's the right file and even use a new floppy, but still no success. Can anyone help?
------------------------------ Q6600 (B3), Gigabyte GA-P45-DS3R, ATI 4870 512 MB, Seagate 320 GB Harddrive, PC8500 G. Skill 2*2GB memory, Xigmatek S1283 CPU cooler, NZXT Tempest Case, Corsair HX 620 Power Supply, HT Omega Claro sound card.
Sponsored Links
Nevermind, successfully ( at least that's what it said) flashed BIOS to F4g. Computer loaded to Windows then the computer rebooted, and now won't post. It powers up for three seconds then resets,and does this repeatedly until I shut it down. I have had nothing but problems with this board.
Reply to rkl525
I see you are using Crucial Ballistix memory. I would stick to bios F2 for a more stable system. There are problems with F4G and Crucial PC8500s.
Dave
------------------------------ P35C-DS3R Rev 1.1 (F2 bios)
Q6600 G0 @ 9x333
ANTEC Trio 650W
Crucial Ballistix PC8500 4x1GB
Reply to dave_99
There are 1194 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
