Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wireless speed drops after a few minutes after boot
Forum Wireless Networking : Wireless General Discussions - Wireless speed drops after a few minutes after boot
I've been having some difficulty with my wireless connection settings. I''m having difficulty even getting around 80kbs from my wireless. I did a speed test from my PC and it came to around 0.8mb, and in real world apps download is limited to that download speed and gaming is impossible, I get massive lag spiked, even though that speed is normally fine for gaming.
Here's the strange part, when I restart my computer, right after the restart if I do a speedtest it will hit the normal 6-7mbs, and gaming will be fine. Several minutes after it reverts to the same ****!
My laptop sits right next to my PC, and if running a speed test from it reveals no loss of speed, I'm getting regular speeds of 6-8mbs. I'm confused!?? I've also disabled firewall.
My PC spec is
Windows Vista 64bit
2*2gb OCZ 800mhz
Asus P5Q-E
Q6600@3.00ghz
Wireless card is: Zonet ZEW1602, I can't even go the website it gives me a warning!
Wiress router: Lynksis WRTG
Any help would be greatly appreciated.
Message edited by Zamundaman on 12-23-2008 at 05:33:04 PM
Sponsored Links
ANything? This is driving me crazy. I've brought the lag spikes down with WLAN Optimizer but speed still drops from around 7mbs to 0.5-1 after 10 minutes? Any suggestions?
Reply to Zamundaman
With wireless, reception and interference must always be the prime suspects.
See if you can detect any neighbouring wireless and move to a channel 5 stops from the strongest.
I assume you have looked at MTU setting in the router (1500 is default, try lowering in increments of 10).
Also try turning off DOS (Denial of Service) protection in the router.
Reply to fihart
There are 1149 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
