Hi Guys,
I just together my system and then found out that my ENERMAX Whisper II EG465P-VE FMA 1.3 ATX 460W Power Supply does not have a 24 pin power connector . Well I need to buy a new power supply.
My current system config is as below...
CPU: Q6600 FSB1066 G0 (SLACR) (planning on OCing to 3.2GHz)
Motherboard: ASUS P5K-E/WIFI-AP (P35 chipset)
RAM: Corsair 2x1GB DDR2 800Mhz
Graphics card: EVGA 640-P2-N821-AR GeForce 8800GTS 640MB
Heatsink: Thermalright Ultima 90
Heatsink Fan: Scythe SFF21F. Fluid bearings, silent, 1600RPM, 63CFM
HDD: WD5000AAKS 500GB, 16MB cache (already have. $130) and 2 SATA 160GB Seagate HDD's.
Optical Drives: one DVDRW and one CDRW
Sound: Audigy2 ZX Platinum
I am planning on buying the below PSU.
OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
But I have read that 8800GTS requires 26A on the +12. Newegg gives the below specs for it : +3.3@36A,+5V@30A,+12V1@18A,+12V2@18A,+12V3@18A,+ 12V4@18A,-12V@0.8A,+5VSB@3.0A.
Will this work with my current system (I have seem some people use this PSU with 8800GTX)?
Also if you guys have other suggestion please let me know.
