Hi guys
I've got a Fujitsu-Siemens computer bought 2003 with an Athlon XP 3000+, 512Mbs of RAM and a GeForce FX5600. The PSU is a VERY cheap 300W (no, I didn't build this computer). The problem is that the machine had overheating problems and it continuously restarted.
I installed a 80mm additional fan in the rear fan place. The restarting stopped but sometimes in the summer when the ambient temp was >27 degrees Celsius (80 Fahrenheit) i couldn't load the machine at all without overheating & restarting.
The solution was a second fan (80mm) in the front fan place. Or that was what i thought.
I know that the front fan is stronger than the rear fan (to ensure the PSU cools down) but anyway the PSU fan (which is a rather low-power) doens't blow like anything out. And the 'anything' it blows feels kinda hot on my hand.
The Graphics Card is the problem causer as it's so large in the case that it blocks the air from coming to the CPU/PSU from below it. And the case is some kind of Fujitsu-Siemens Scaleo original (full-ATX tower).
The additional front fan didn't help anything except the graphics card with a few degrees. The idle temps are 48C (118F) for the CPU and 78C (172F) for the GPU, load temps (playing DRIV3R) CPU: 52C (125F), GPU: 80C (176F).
There are no more empty fan slots but i might make some additional blowholes if necessary.
Thanksful for any help.
mm_vr
mm_vr
