Tom's Hardware > Forum > Storage > Hard Disks > Help! What's my ideal set-up?
Forum Storage : Hard Disks - Help! What's my ideal set-up?
Let me start off by saying this, I am completely lost! It's been many years since I've taken a serious look at the hardware side of computing (finally time for a major upgrade) and I last was on the scene when SATA started to come about. Since then it appears quite a lot has happened (and is happening, flash comes to mind), and I was hoping someone could help me out a bit or point me to a website with (perhaps less sophisticated, more novice friendly) information regarding current HDs.
I'm starting to gather information to build a new machine (just looking to see what's available, mixing and matching things, I'll probably actually buy something late January to mid March). A few things that confuse me; what's the difference between a 3.5" and 2.5" HD, what exactly is AHCI (I think it's required/used in all SATA setups?), and is NCQ a big deal (something to make sure to get)? 7200 RPM or 10,000 RPM, SAS or SATA? Another big question I have is should I get two hard disks (one for OS and related 'essential' use programs) and another one to dump games in?
I'm building something more towards games (generally that's what I use my computer for, in addition to the typical web-surfing, mp3 use & ripping, and work related use), ideally I'd like total storage around 250-300 GBs (I generally like to leave a few games installed at once as my tastes vary and I find myself skipping around game to game). I have no experience using any sort of raid environment and would prefer to avoid it if possible (unless there are substantial gains to be had).
If anyone is able to help, offer advice, I would really appreciate it. I know I asked some pretty broad and heavy questions so if anyone is able to offer a newbie-friendly website or resource I would greatly appreciate it!
Message edited by Exquisite on 11-02-2007 at 09:13:48 PM
Sponsored Links
A 2.5 hdd is for laptops while the 3.5 is for PCs. All new mobo can handle SATA drives and Windows includes the drivers. NCQ is an interesting questions, haven't seen anything about that in forever. Either all hdd drives have it or few, if any, are using it. As for 7200RPM vs 10,000 it comes down to your budget. Intel is coming out with some new CPUs in the next couple weeks/months and they finally have the X38 mobo out. AMD is also coming out with new CPUs but you never know when this will happen with AMD. Suggest you start research P35 and X38 mobo dual core and quad core CPUs, tomshardware is a good place to start as well as anandtech.com and exteretech.com but there are a lot of other good sites. What's best for you depends on how you'll use it and your budget. When you're ready to buy you'll have a good idea what you CPU you want, which pretty much determine the mobo chipset. Once you know this, people can give suggestions.
Reply to g-paw
Thanks for the input g-paw, I appreciate it!
Reply to Exquisite
Get luck with your research, can be fun
Reply to g-paw
There are 1180 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
