Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Something to monitor the temps in my case, need recommendation
Word :   Username :
Bottom
Author
 Thread : Something to monitor the temps in my case, need recommendation
Profile: addict
More Information
Does anybody make anything that will monitor, with independent sensors, the temps inside my case?
I have a sneaky feeling that my Ultimate 120 extreme is not placed properly, even though my temps are fine. I want to know what the inside temps are so I can gauge the difference between case temp, outside temp and core temps.
I am thinking my idle should be closer to my outside ambient temp.
Example of my problem. ambient outside temp in my room, 25-26c. Idle tat is about 40. Load gets upto high 40's never more than 50c using dual prime95.
With out OC, but same voltage, my idle tat is 38-39c and load is never higher than 44c
set up is
e6300 at 431 x7 voltage is 1.20 (yes under volted)
GA-965p ds3
Ultra 120 extreme with a 120 scythe flex
Big *** case with 2 120's as out fans (back and blow hole)
and 1 120mm intake front bottom and a 80mm on side
Related Product
Profile: member
More Information
I think Thermaltake makes somethign you can stick in one of the CD-ROM drive bays. It has a digital temp readout and comes with a few different probes you can place in different parts of your case.
Thermaltake Armor Series Case - ASUS P5K Delux Wi-Fi Motherboard - Intel Q6600 2x4MB Cache 2.4GHz....@ 3.6GHz - 4GB G.Skill PC-6400@1125MHz 5-5-5-12 - EVGA GeForce 8800GTX - 2x 150GB Western Digital Raptor X (RAID-0) - 40" 1080p Samsung LCD.
Profile: journeyman
More Information
I think your temps are just fine and low enough, my Athlon XP 3000+ runs 48c idle and 52c on load an the ambient is ~26c.
Google Ads
News
LCD-monitor OEM prices continue to fall in December
Published on December 02, 2004
LCD-monitor OEM prices are expected to drop this month, with 15- and 17" monitor quotes to drop US$3-5 and 19" monitor prices to fall US$5-10, according to Taiwan-based monitor makers. Read more
BenQ 2ms LCD monitor to hit the market in November
Published on October 27, 2005
BenQ recently debuted its 2ms 19" LCD monitor (FP93G X), which it claims to be the world&'s fastest monitor. Read more
LCD monitor vendors betting on widescreen models
Published on November 15, 2005
First tier LCD monitor vendors such as Acer, BenQ, ViewSonic, Hewlett-Packard (HP), Samsung Electronics are all eying the large size widescreen LCD monitor segment, though some panel makers hold a more conservative attitude toward the widescreen market, according a Chinese-language ET Today report. Read more
LCD monitor makers report declining shipments
Published on September 12, 2005
Taiwan-based LCD monitor makers posted mixed results last month with most manufacturers, including BenQ and Lite-On Technology, experiencing a drop in LCD monitor shipments, according to the companies. Read more
Latest Reviews & Articles
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
