Realtek ALC850 @ nVIDIA nForce4 (CK8-04) - Problem
Forum CPU & Components : Sound Cards - Realtek ALC850 @ nVIDIA nForce4 (CK8-04) - Problem
Realtek ALC850 @ nVIDIA nForce4 (CK8-04) - Audio Codec Interface.
This is my on board sound card for my nforce 4 gigabyte system. My motherboard is ga-k8ne rev 2.0.
Before I changed my case it was all ok, but after my green line out on my sound card is not working.
I tryed the blue one with control panel i managed to get this one working so I am getting sound from my comp from blue line in switched to line out.
I tried a big cleanup in my case but it didint helped.
After this I installed Linux (Kubuntu 7.04) , it recognizes my sound card but yet the green line out doesent work
In device manager everything shoes up ok.
I didint mention that in the blue line out, i get crapy quality sound (not scraching but sounds like comming from the basement)
Why is that, i have screwed my soundcard????
Sorry for my bad english.... :pt1cable:
Sponsored Links
Probably not; uninstall/reinstall the drivers. Also, search Microsoft's website for "HD Audio Codec". There should be a separate update you can install that might solve this problem paired with reinstalling your drivers.
------------------------------ Thermaltake Armor Series Case - ASUS P5K Delux Wi-Fi Motherboard - Intel Q6600 2x4MB Cache 2.4GHz....@ 3.6GHz - 4GB G.Skill PC-6400@1125MHz 5-5-5-12 - EVGA GeForce 8800GTX - 2x 150GB Western Digital Raptor X (RAID-0) - 40" 1080p Samsung LCD.
Reply to localcpuguy
I have tried driver Uninstallation, it didint changed anything. I have downloaded latest driver from realtek website but nothing changed.
Reply to ferencster
On some mobo's you have to set a jumper to configure sound to the rear panel or the front headers as you have changed cases have you checked for this?
Reply to mousemonkey
OAAAAA... THanks mousemonkey. It worked. I used the manual and disable the front panel audio by jumpers, because I used front audio with my other case. NOW IT IS WORKING FLAWLESS. Thanks again.
Reply to ferencster
[:mousemonkey] Glad I could help mate, I had the same thing happen to me a few weeks ago and after a bit of [:mousemonkey:2] it was a [:mousemonkey:4] .
Tom's Hardware > Forum > CPU & Components > Sound Cards > Realtek ALC850
There are 594 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
