Test for blown system
Is there any quick or easy way to test my system to see if the Mother board or the cpu is blown. I have swapped out the power supply so am pretty sure that is not the problem. Wonder how to test the other two for reason why system is DOA.
Dean
1 answer Last reply
More about test blown system
  1. Check the caps on the mobo for bulging and/or leaks and take the CPU out turn upside down and check for browning, other than that it's a case of swapping bits until the problem goes away.
CPUs Power Supplies Motherboards
