I am looking for a new video card for my new Q6600 - P5K Premium - P812 system.
I am considering a 7900GS, 8600 GS/GTS or 8800 GTS (maybe EVGA e-GeForce 8800GTS Superclocked 320MB). I plan to use this PC for a few years without any upgrade.
Besides the money, does the 8800 consume more power and generates more noise than the 7900 and 8600 series cards?
Yes and probably, although yes and yes is more likely closer to the truth.
I'd say YESY and YES, but most importantly on a build you want yo 'use for a few years without any upgrade' then most importantly of all IT's WORTH IT !!
IMO, anything less than a GTS for such a build is not a good fit.
------------------------------You need a license to buy a gun, but they'll sell anyone a stamp (or internet account) - REDGREEN. GA to SK HD Freedom: 45 5F E1 04 22 CA 29 C4 93 3F 95 05 2B 79 2A B2
Reply to TheGreatGrapeApe
i find that my evga 8800gts 320mb is VERY quite even for running the fan @95% all the time. big difference between the two tho. owned a 7900gs(modded) and it doesnt even come close to my new card.
In my build the GTS 320 is easily the loudest thing in my case when it's fan is on 100% but as the other felles stated it's well worth it. This thing is blazing fast stock and it overclocks verry nicely to. I have mine set with rivatuner to keep the fan at 60% when on 2D stuff and at that speed you won't hear it. When it's on 3D stuff it kicks the speeds upto 610/950 which is a relatively modest overclock and the fan to 100% which I can't hear over my surround while playing. The noise isn't really a bad tone anyhow, I've heard worse on my modded x800xl. Bottom line just get the 8800 and you'll be alot happier.
I am thinking to get the EVGA GeForce 8800GTS Superclocked 320MB. Any comments on this card?
I never used Rivatuner. This card is already OC so I don't plan on any further OC. I sure like to monitor the temperatures of this card. Also, looks like you can set the fan speed as well but why do you want to control the fan speed? Shouldn't the fan speed be determined by the temperature of the card?
Like I said, I do not plan on making any further upgrade to this PC for a few years. This is why I am getting all the quality components (P5K-Premium, Q6600, Freezer Pro-7, P182+1 extra case fan, Cosair-620W, etc).
Since this EVGA and BFG cards are in the same price range and similar perfromance, I will buy the one which is more reliable and quiet.
If they are the same price get the card with higher clocks and better waranty.
I've never heard of a 8800gts 320 overheating or even being that hot so I wouldnt worry about temps. The p182 is a good case with good airflow. I'm not sure why you would need an extra fan in there.
Everything else is equal. They're both excellent companies with great quality and great warranties.
I would say eVGA, it's pretty obvious. The S-Video cable may be useful, the higher clock helps, and the T-Shirt is not worth $25. I got one with my BFG 8800 GTX OC2 so I know exactly what I'm talking about It's black, it says BFG on the front in white letters, and the back is a guy's head with blue skin and orange eyes and the logo "Gamer's Choice". At least they sent me an XL so I can actually wear it. I wonder if they send XL to everybody
Is that the technology BFG used in their 8600 GTS? I read something about recently. It's very very nice especially wrt noise but it adds $50 to the cost and it doesn't really make sense for a 8600 GTS. It makes sense for an expensive and very power hungry card. I'm sure it will be in their 9800 GTX.
Well, it is cheaper to just have a fan without also adding a smart controller for it, I guess. It's also stupid, of course, because it increases noise, power consumptions, and the chances that the fan will break. I hope it's not true. I'll try to find out.
I'm confused. Here are two reviews. One shows that the noise of the 8800 GTS increases under load, and one shows that it doesn't. A noise increase under load would mean the fan is NOT always running at full speed. The problem is, who is right here? Both Anandtech and XbitLabs are reliable sites, so I'm guessing it's just me being unable to make sense of the numbers.
eVGA, just because I have had support issues with BFG. I spent a lot of time convincing the tech that it wasn't my power supply causing the lockups, even though I was continually montioring voltages and temps. It was a heat problem with the card.
Just curious, as a BFG card owner, how did this horror story end? Did BFG send you a new card? Did that one work? Did you have to send your old card first and spend some weeks without any card? Did you have to pay shipping for either the old card or the new one? Thanks!
make SURE you monitor your temps with ntune or something similar..I bought a second evga 8800 320 superclocked and my old card operated at 107 degrees C in SLI until i moved it to PCIex number 1 position (close to CPU), only then did it drop by 40 degrees.
Watch the temps! get the OC version or save your money and when the G92 cards come out, get an 8800 ultra at the reduced price!
