Hello, all, I'm new to this forum, but I've been actively reading different help topics. I know that this topic has come up in several different threads which I believe I listed correctly for reference. They didn't answer my specific questions however. I have been building computers for a while now but still consider my knowledge limited. The newest system I have put togethor is having problems. It should be listed in my profile, but in case it is not displayed:
Asus M2N-Sli Deluxe
AMD Athlon 64 X2 5600+
Corsair XMS2 Dominator 2GB PC2-6400
EVGA GeForce 8800 GTS 320MB
Hard Drive 2X 120GB
Sony DVD+-RW
Thermaltake PurePower 480W
The problem I seem to be having is that when I start up a game most run fine until I get to the actual game play, or the demanding graphics part, where the entire computer will turn off. This leads me to believe that I do not have enough power. The PSU I currently am using is an older unit and does not have the 24pin power for the MOB. I got a converter for that and the new graphics card.
- Can someone please advise whether my conlusion is correct about the power?
- How do you determine the correct Watt rating to power these new parts and if I wanted to run sli soon?
- I've read that the graphics card needs 26A on the +12V rail, then why do most PSU I look at only have 18A?
- If there are 4X 12V rails do you add the Amperage? (ie. 4X 12V @ 18A = 72A in sli 36A)
Asus M2N-Sli Deluxe
Hard Drive 2X 120GB
Sony DVD+-RW
The 8800GTS requires 24-26 amps on the 12v rail(s) minmum. Before you install a more powerful psu you might try going in BIOS and setting the memory voltage to mfg. specs, 2.0-2.1 volts.
What would the voltage for the memory default to, and is that a lower voltage which would alter the performance?
According to the psu calculator I may need up to 800 watts for the system I would eventually like to build.
I still can't find a psu that supplies 24-26 amps the 12v rail. Please advise what product carries this supply??
What would the voltage for the memory default to, and would it change the performance?
In Bios check your memory voltage. I believe the Corsair you have is 2.0-2.1 volts. Set the voltage to the mfg specs.
18 amps x 4 12v rails for $79. Your system will not use 800 watt unless you have a home appliance attached to it. It is the 12 volt amps that make the difference what psu will power your system.
Hey Badge, thanks a lot for your quick reply, sorry but i'm still confused how those psu's will work because there should be 24-26A on the 12v rail but the one from OCZ only has 18A on four different rails. If I were to plug in the video card to one does it pull some amperage from 2 rails to make 26?
Those rails can usually add together and if you look at some reviews, 8800's pull about 160 watts each max load, so that is 320 in sli JUST for the cards, plus you need some for your system, on top of that, it is better if you don't run your power supply maxed out, so you need a lil extra, it will last longer, something like a good 550 -650 is a range to leave you some room to breath if you go SLI. 480 sounds like plinty with what you have so far though, but quality or sometimes defects mess up what is on the sticker.
"Now if the 4870x2 was actually notably faster than the 280 for about the same price, then I might even take a chance on it. However, that won't be the case."-robx46
I looked up the voltage parameters for the RAM. The Corsair website actually recommended a setting of 2.4v. I set that and the cpu to the recommended voltage and tried again to run my computer. It worked for about 5 minutes under high graphics demand and turned off. (no blue/frozen screen, just all power was shut down)
Does someone know if it is the psu that is causing that kind of problem? I cant think of any other reason that the computer would just shut down unless the power is cut off from too much demand?
