Tom's Hardware > Forum > CPU & Components > Sound Cards > Installing my X-Fi extreme gamer sound card, help : (
Forum CPU & Components : Sound Cards - Installing my X-Fi extreme gamer sound card, help : (
i have this PC http://www.peachdirect.com/product [...] ry=5016&am p;_UserReference=42C93F0F46EB294C75163573F76046BFA2FC
And I have both of my PCI slots full with my GPU and a 15 in 1 media card, can my motherboard run a my new sound card or should i take out the 15 in 1 media sound card? Im very confused. could you help me? can i run my X-fi sound card?
thanks
Sponsored Links
15 in 1 media card in the pci slot?
and what hp system do you have the page does not say?
Reply to Joe_The_Dragon
I don't really understand your setup. You can only run the sound card if you have a pci slot to put it in. Most mobo will come with more then 2 slots though. I do not understand the 15 in 1 media sound card part, is it a media card or a sound card?? If you have an open(unused) pci slot, or plan on removing something to open a pci slot then you can get the xtreme gamer in your pc. rember, put it in the slot farthest away from your video card.
Reply to smokedyou911
This is my set-up, i only have 2 PCI slots
http://www.peachdirect.com/product [...] subCategor y=5016&_UserReference=42C93F0F46EB294C75163573F76046BFA2FC
Reply to troy88
I saw this on the page you linked.
Expansion Slots 2 PCI slots (occupied), 1 PCI Express x16 Slot (occupied), 1 PCI-E x1 slot (occupied)
You'll need to take something out of one of the PCI slots (the white ones) to replace it with your X-FI card, it says that the system comes with a 56k dial-up modem, do you need this? If not, just pull it out and replace it with the X-FI.
Message edited by locky28 on 08-13-2007 at 03:32:05 AM
------------------------------ Intel Core 2 Duo E8400 | GA-EP45-DS3R | 2x2GB G.Skill NT DDR2-800 | Gigabyte HD4850 512MB | 2x WD Caviar SE16 500GB (Raid 0), WD Caviar Green 1TB | Lian Li A07B w/ Noctua Fans| Seasonic S12+ 650w | LG 22" 2ms
Reply to locky28
There are 1236 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
