I tried searching, but nothing turns up with the search variable fan, that I could find that would answer my question.
Im planning on getting a Thermaltake Ultra-120, and I know I would need to buy a 120mm fan. I was searching around on newegg.com (I find it the best, at least to pick parts), and I see three different kinds of fans. They have some that say they have a range such as 35-95 CFM. There also some that will have a few settings such as 20, 40, 60 CFM. Then there are the ones that just have one rating, ex: 45 CFM.
I want to know if the ones with just one rating can be controlled by your motherboard or a fan controller, or if they are truly just one speed. I also wanted to know if the fans with the three numbers can be controlled or if those ratings are the only settings they will run at.
My dilemma is that I want a fan that can perform when I need it too, but I don't want something that will sound like a tornado all the time. I know you are saying, just pick one of the variable speed fans, but from what I've seen, the selection is slim and the quality isn't up to par with the one speed fans. Any thoughts are useful. Thanks for the help!
