Ok my pc is 2 floors from my router, i have Fios interent. i pull about 6 megs from speedtest so i have a good connection. i just need somebody to recomend a great online-gaming card... please i lag like crazy on the cheap dynex adapter. i would prefer pci or pci-e but usb works too. thanks!
help!
At that range you may have speed problems with any brand -- you may have to look to extended range models -- and that may mean changing the router too.
Also have a look at mains plug network adapters -- cost a bit more than wireless but less problematic.
