Hello!
I have problems with my new Asus P5K-based system.
For example, while listening music with Winamp the sound freezes for short time (maybe 1/10 seconds or something) but this happens regularly and it's very annoying. I used the same sound card on my previous system and all worked fine! During these short "freezings", the mouse cursor will stop also for a short moment. Music freezes something like "TRRRRR!!" and goes on again...
I think these mouse cursor and sound problems will occur when reading some data on my IDE HDD, which is my primary HDD (os installed on it)
I readed somewhere that the problem could be that the os has been installed on IDE HDD instead of SATA? Is there any sense? Could the P5K's IDE-bus be so poorly working?
I've tried to update drivers to the latest version but nothing seems to help. P5K's onboard sound chip is disabled from BIOS.
This Windows XP install is old, I didn't need to reinstall Windows during hardware update. But everything else seems to work just fine so I don't think that's the problem.
I'd prefer not to install OS and all the programs again on my SATA drive just for testing if the problem could be solved that way, so if you guys have any other idea to solve this annoying problem I would be very thankful!
My system:
Asus P5K (not "deluxe" etc)
Core 2 Duo E6600 @ 3,6GHz (400 x 9)
4 x 1 GB Kingston 667MHz DDR RAM
Club 3D GeForce 8800 GTS 320MB
Seagate 120 GB IDE as primary HDD (OS installed on that)
Seagate 300 GB ATA as storage HDD
Seagate 500 GB ATA as another storage HDD
Soundcard: Terratec Aureon Space 7.1
Windows XP Pro SP2 with all security patches
My system:
