Hi,
I have2 system, one purchased and one home built. They more or less have the same specs and both are running windows xp media centre edition 2005 OS.
The pre assembled system boots up a lot faster so how can I change or make the boot sequence better on the homebuilt?
Also I downloaded IE 7 on to both and on the pre-assembled it runs fine but on the homebuilt it gives an error everytime you click on the drop down menu at the side of the address bar, and shuts IE down. Has anyone any tips to fix this or wht could be causing it??
Thanks
Thanks
