I wanted to ask if you think my hard drives will be safe if I transport my computer case in a truck. I am driving from Atlanta to Hollywood and I will put the computer- probably sitting in the truck bed in a box. I asume the hard drives will be fine with all that vibration right? As long as the box dosnt fall over or anything.
Your hdd should be fine but if not, easy enough to reinstall. If there is anyway to put them in the cab, I would. If not, rap the boxes in thicker plastic to make sure they stay try. I'd also make sure the box are well patted with an old blanket. Also would put them near the bottom but not right on the bed and have a lot of stuff on top. Make the boxes as secure as possible, keep it dry, and well padded
Hard disks are typically rated at 200+g of short-term acceleration while they're powered down, so unless you drive off a cliff you should be fine. My PC survived being transported by boat, truck and who knows what else for thousands of miles from Europe recently with just bubble wrap inside the case and then packed in the original cardboard box that it was shipped to me in.
To be honest, I was more concerned about a PCI card or heatsink or something else coming loose and rattling around inside the case; hence stuffing it full of bubble wrap to minimise any damage. As it happened the only thing that did fall out was the SCSI cable (which has always been loose) and that just plugged back on.
Just keep the hdd on your lap if you have to go somewhere bumpy... Honestly i would not subject it to the boot of a car if i could help it.
DONT PUT IN IN THE CUBBY HOLE, a friend of mine did and a pen tore through the seals and broke the hdd, and keep it in an anti static bag if you have one.
Vibrations are only an issue during operation (I should know as I destroyed an HD that was operating in a rail yard). Vibrations during shipping and transporting are not an issue (or how else could Dell and Hp ship millions of computers with HD's via UPS etc).
Just protect from moisture and impact from other goods. And inspect for loose cables and connections (such as heat sink) prior to first operation after you complete your move.
------------------------------I am old enough to be your grandfather.
It was born a Dell, it was made into a computer by StevieD
Reply to StevieD
Personally, I'd be a lot more concerned about over-sized CPU heatsinks bouncing around than my hard drive. The hard drives can take quite a jolt when they're not in use. As someone else posted, around 200G's.
Lay your computer on it's side that way the CPU heatsink and GPU and pushing down on the motherboard rather than pulling. The motherboard will take the stress much better if you lay your computer on its side.
Don't worry about it. I have a LAN machine I lug around once a month and I have never had a problem. When not in use it sits in the garage which is subject to the ever changing temperatures and I have never had a problem.
------------------------------Athlon 64 AM2 6000+
Gigabyte M61P-S3
4 GB OCZ Fatal1ty DDR2 800
Asus 4850 512mb
Reply to caamsa
The main thing is to shut down your computer properly, dont just pull the plug as the harddrive's heads will remain in their read/write state. Otherwise just use common sense.
