Tom's Hardware > Forum > Homebuilt Systems > New System Build > Whew... need building help!
Forum Homebuilt Systems : New System Build - Whew... need building help!
Hey everyone! Well, my old desktop computer crapped out on me earlier this summer but since I was keeping pretty busy I didn't really feel the drive to replace it. But I think it's about time that I weigh some options if I'm gonna be ready for the Winter boredom (aka. Gaming season).
Anyway, let me get to it...
Basically, I have a meager $500 to spend on this replacement and I wouldn't be sad if I could get away with less. I don't need anything too flashy just good enough to run the basic games (various old games, World of Warcraft, perhaps a new MMO or 2) and I'm not concerned with uber graphics, typically happy to run things on low settings as long as it remains somewhat smooth. Very interested in starting small and upgrading at a later date when the money comes around.
I do already have 2 monitors that I plan to reuse, so I won't need new ones. And I'm probably going to need Windows Vista as well, so that probably takes a chunk out of that $500.
Well, I would be happy with any help anyone could give me!
Sponsored Links
I should probably also add, that I have a pair of 1GB DDR PC3200 RAM sticks... and I'm going to assume that they arent going to be able to be reused? If so, perhaps I can pawn them off on E-bay for some change along with my AGP x1300 ATI graphics card.
Reply to lawrencethomas3
- 0 +
Just a little above the budget but this is what I'd go with for $500:
Raidmax Smilodon $90
http://www.newegg.com/Product/Prod [...] 6811156062
Gigabyte GA-P35-S3L $86
http://www.mwave.com/mwave/viewspe [...] ia=BA24072
E4400 @2.0Ghz $119
http://www.mwave.com/mwave/skusear [...] ia=BA23789
2GB Super Talent DDR2 800 $94
http://www.newegg.com/Product/Prod [...] 6820609026
EVGA 7600GT $75
http://www.newegg.com/Product/Prod [...] 6814130062
LG 18X $28
http://www.newegg.com/Product/Prod [...] 6827136119
200GB WD $55
http://www.newegg.com/Product/Prod [...] 6822144416
$547 after $25 in rebates.
Everything is very upgradeable just like you asked, Video card & CPU should be first. Until then, this little system should run everything pretty smoothly, depending on the settings. You can realistically expect WoW to run on High though :)
Good luck.
Message edited by Dior on 08-15-2007 at 08:43:26 AM
Reply to Dior
- 0 +
well i think some more info would help us out. for example you say it crapped out on you.. what exactly isn't working anymore? hard drive? motherboard? so tell us exactly what you already have that you know works so that we can put together something around those parts.
Also, why do you *need* Vista? if you're doing light gaming with some older games i think XP would be just fine for you (and prolly cheaper as well) so get us that info...
Reply to shoota
- 0 +
If your trying to save some dough, which most of us are, I would recommend the AMD for your setup. I know the C2D's are better, but when budget restrictions are needed, the AMD's right now are it. Here is what I would recommend using.
Case: I know this isn't the best but I've built 2 systems with this and no problems whatsoever. Check out the 25A on the 12V rails for this price :wahoo:
Athenatech A412BB.400 Black / Silver Steel ATX Mid Tower Computer Case ATX 2.01v 400W Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6811190073
$51!!!!
CD/DVD Burner: Free Shipping!!!
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner With 12X DVD-RAM Write - OEM
http://www.newegg.com/Product/Prod [...] 6827106070
CPU: Just getting cheapest x2 you can get now and room for upgrade later.
AMD Athlon 64 X2 3600+ Brisbane 1.9GHz 2 x 512KB L2 Cache Socket AM2 Processor - Retail
http://www.newegg.com/product/Prod [...] 6819103046
$61.50
Mobo : Combo deal saves you $5 and this board is great, from my experience.
BIOSTAR TForce TF7025-M2 Socket AM2 NVIDIA GeForce 7025 Micro ATX AMD Motherboard - Retail
http://www.newegg.com/product/Prod [...] 6813138074
$71 with the $5 discounted package w/the CPU.
Memory: 2GB to handle minimal amount needed for VISTA (if you want to use Vista).
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6820231098
$89 w/free shipping!!
Graphics Card: Good solid and cheap Video card.
EVGA 256-P2-N615-TX GeForce 7600GT 256MB 128-bit GDDR3 PCI Express x16 SLI Supported Video Card - Retail
$96 out the door, but has $15 MIR if you so desire to cash in on it!
OS: If your going to use Vista, than this will fit into your budget.
Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD - OEM
http://www.newegg.com/Product/Prod [...] 6832116202
$111 w/free shipping
TOTAL = $510.07 Shipped to my house and if you cash in on MIR's you get:
$495.07!!!! Now that is streaching the Budget!!!
I personally would get Windows XP Pro/Home if I were buying this system, but that is my opinion.
P.S. My setup HAS the OS built into the price (not that my system is the greatest though), but the previous build had no OS included, which would've added at least $100 more to his setup.
Message edited by lunyone on 08-15-2007 at 09:30:22 AM
Reply to lunyone
- 0 +
shoota is right, we need more info. You said your old system died well what exactly is the problem? Did the PSU go? If so just buy another. Did the hard drive go? Again buy a new one. Did the motherboard get fried? Well in that case you will most likely need several new parts depending on if it took anything else with it (same as a blown PSU) but you still should have a useable case, CD/DVD drive, possibly PSU, possibly hard drive(s). All these factors combine to give us the chance to help you determine the best use of your money.
Message edited by ausch30 on 08-15-2007 at 09:48:35 AM
It is the mark of an educated mind to be able to entertain a thought without accepting it.
-Aristotle
Reply to ausch30
I'm not exactly an expert, but from what I figure... the motherboard seems to be boned. It stopped recognizing both primary and secondary drives (both with a master and slave) and upon switching cables the problem remained the same. I'm going to check the HD and CD Drives out on a friend's computer tomorrow, as it seems unlikely that all 4 would go out at the same time. Of course, it would probably be of note that all of these drives use IDE cables, so I would think that to reuse them on a new system I would have to have an SATA converter?
- 0 +
Try this Mobo out if you want 2 IDE connections (4 HDD's or whatever you need).
http://www.newegg.com/Product/Prod [...] 6813131143
It's cheaper than the one that I posted above. Hope this helps out. You can also buy a PCI slotted board that can give you more IDE connections, if I remember right.
Here it is, something like this.
http://www.newegg.com/Product/Prod [...] 8081&Tpk=i de%2badapter
Out of stock though..
Message edited by lunyone on 08-15-2007 at 03:34:20 PM
Reply to lunyone
And the computer is an old Dell 4600, so I'd imagine that I'm stuck getting a new case.
- 0 +
The cheapest option would be to just by this, http://www.newegg.com/Product/Prod [...] 6813138262, and call it a day. Should fit in your case and work with everything you have.
-Aristotle
Reply to ausch30
- 0 +
Just be warned that Dell likes to use propriety connections and you might be better off just starting from scratch. If you want to continue to use the AGP card you have (and thus limit further upgrades) go with what AUsch30 says and use what I stated in previous post. I would start from scratch, if I were you and could afford the $500.
Reply to lunyone
- 0 +
Don't get the motherboard AUsch30 recommended for the simple fact that AGP is a thing of the past. If you can verify what you have that works and let us know for sure then that $500 dollars can be better spent and you'll wind up with a much better PC than if you bought all new parts. So we'll just wait...
Reply to shoota
- 0 +
if you like u could have an e2160 instead, if your really tight on your budget... just over clock it, you could achieve 3GHz with no sweat... a gigabyte P35 will do the job...
Reply to queue
Thank you for all the help, people! It turns out I have no way of verifying if these hard drives still work as I don't know anyone with a desktop that uses IDE cable connectors. If I go with a mother-board that uses SATA connections, is there some sort of converter available? That way, I can get the parts I need (sans a new hard drive), test out the old HDs, and... if bad comes to worse, I can just buy a new one.
To anwser some other questions:
- I just assumed that Vista was the way to go. It turns out I have a copy of WinXP that I likely borrowed from Work some time ago that I can use.
- I'd rather not just replace the mother-board for a couple of reasons... 1. I'm not abosolutely sure that it is solely the motherboard that is the problem. 2. My computer was some 5 years old and probably needed replacement anyway. and 3. Being an old dell model, I would imagine that I'd have to channel MacGuyver to complete a mother-board replacement on that computer.
- Finally, I know my budget is tight, but I'd rather not be stuck with obsolete components that don't give room for an upgrade (AGP mother board/ non-SATA mother board). As I hope some computer money may find its way into the ol' pocket book soon.
Well, I hope that's about everything... I really appreciate all the help!
- 0 +
All motherboards have legacy PATA support so no matter if everyone you know is using SATA drives their motherboards still should have at least 1 PATA connector which you can connect 2 devices to so you should be able to at least find out if they work. Here http://www.tomshardware.com/2007/0 [...] _marathon/ is an article tom's did about building a budget system and they did it for $525. This article is 3 months old so prices of the components have dropped and with your copy of XP your optical drive(s) and if your hard drive(s) work you should be well under $500.
-Aristotle
Reply to ausch30
There are 1233 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
