What power supply to get?
I'm just buying the parts for my new setup and dont know what power supply to get.
The setup is as follows:
Core2Duo E6750 2.66Ghz 1333Mhz FSB
Asus P5NT-WS 680i Chipset Mobo
CorsairTwinX XMS2 EPP DDR2 PC2-6400 (800) CAS 4-4-4-12
E-VGA 8800GTS 320Mb
SATA150 200Gb Seagate
SATA 300 500Gb Seagate
IDE 250Gb Maxtor
Old Ricoh IDE DVD writer
I'll also be running 3 120mm case fans + of course the exahust fan on the GFX card. No lights or anything
Eventually I guess I will upgrade to a second 8800GTS to add a bit of life to it, but for now it will just be the one.
I'm going to run it on a generic 500W power supply for a start, but would this cope? Im not planning on overclocking yet, but may do once Ive got some better cooling later on. Im on a VERY tight budget now, (I spent as much as I possibly could on the setup and then some).
Any suggestions welcome, but the cheaper the better. I know I'd be better off getting a branded one, but I dont want to pay much more than about £60 (120 USD)
Thanks
8 answers Last reply
More about what power supply
  1. Why are you getting a fully capable SLI board when you arent using SLI?
    I would drop back and get a P5K series Asus which will give you a newer chipset in the P35.
    I wouldnt recommend running off the generic PSU but it "should" be enough. I would look at a PSU with 2 if not 3 12v rails Antec NEOHe or a Trio... even Thermaltake toughpower
  2. I wouldn't spend that kind of money on a system and "run it on a generic 500W power supply" Look into Corsair's 520HX or 620HX.
    :bounce: 12vdc amperage is more imporntant than how many 12v rails it has, a crap PSU can have 3 12v rails.
    You are asking for trouble bigtime! I suggest getting a PSU that can handle the new standard, PCI-Express 2.0 8pin power connector. Heres a link to better explain. http://www.pcisig.com/news_room/faqs/pcie2.0_faq/
  5. Look here ...... http://www.thermaltakeusa.com/
    I just got a 650w and it looks great, very quiet.
  6. I've an 850w silverstone from Scan, was a bit more expensive but they will have a model in your price range. Konplett and overclockers are good to buy from as well. The corsair mentioned above is highly thought off on the forums.
    If you'd read my orginal post, I'll upgrade when the price of them come down somewhat.
    As for the rest, thanks for your help. I think I will go for the Hiper 580W Type M one.
    http://www.ebuyer.com/UK/product/109552
    My friend has just set up his computer with the E6700, 2 8800GTS 320Mb, 3 hard disks in a raid array + 2 extra, 2 DVD writers 6 120mm fans, 3 blue LED sets and 2 cathode tubes! He's overclocked the 8800's and his proccessor a little and it runs as smooth as a babys bum!
    Im not going to be running half that so it should be OK.
    Joe
  8. Quote:
    Sorry joe seems i missed that bit in your original post. I am a little blind hehe
    Good choice on getting a decent PSU, you will be happy with the outlay, and will put your mind a ease a little also
Power Supplies Components
