Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Which chipset should I go for?Which mobo for these parts?
Forum Motherboards & Memory : General Motherboard - Which chipset should I go for?Which mobo for these parts?
This is going to be my new gaming rig:
Q6600
8800GTS or 2900XT
2Gb Crucial Ballistix 800mhz 4 4 4 12
Corsair 620W PSU
Thermaltake Armor LCS with watercooling kit.
What chipset should I get?Ive heard that the 680i are for SLI,which Im not interested.I have been told to go for Itel's P35.I also want to Overclock.Which mobo do you recommend?My budget is $150-180.
Message edited by starmanwarz on 08-26-2007 at 02:54:19 PM
Sponsored Links
GIGABYTE P35 DS3R and ASUS P5K-E (if u want only DDR2)
GIGABYTE P35C DS3R and ASUS P5KC (if u want both DDR2 and DDR3) ,
the first choices will OC better
------------------------------ Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
i would go for the Gigabyte P35 DS3R
Reply to boner
I never had any experience with Gigabyte boards,are they really good?Any other recommendations?
Reply to starmanwarz
Well the advantage to that gigabyte board is 8 sata ports not the 6 most boards have(DFI is an exception but out of budget too).
They give you the bracket to send 2 of those as e-sata ports for those who want it.
There is not wifi or firewire(was not a concern for me).
Last off P35(from any company) chips are made for FSB 1333 so even a 1066 cpu will run at this speed with little to no voltage increase(3.0 easy you can get more if you want it, 400 seems easy as well[wont keep that in air in a 30c room]. i would not go farther then that with a 9x multi.).
For Alternatives you can look at the
ASUS P5K-E/WIFI-AP - http://www.ncix.com/products/index [...] omoid=1078
or plain
ASUS P5k - http://www.ncix.com/products/index [...] omoid=1078
I have not used either of those boards. but they are in the right price range.
Message edited by nukemaster on 08-26-2007 at 11:50:15 PM
------------------------------ http://i33.tinypic.com/sw3a5y.png
http://tinyurl.com/26uxxb - C2/i7 Temp? http://tinyurl.com/cj3pw - VGA power?
http://tinyurl.com/5v55wk - C2 Mem performance? http://tinyurl.com/6pmbke - SLI/Xfire?
http://tinyurl.com/yfmxdc9 - Part Guide?
Reply to nukemaster
i have used P5K-E and i love it :D
Reply to Maziar
There are 1013 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
