I just to ask is it my standard power supply(500 Watt) is enough and safe for long hours since I just bought Winfast A7600 GS 256 MB DDR2 AGP 8X which requires extra molex connector.the minimum for power supply which is required for A7600 GS is 300 Watt.Also, my casing have 5 LED fan including mainboard chipset cooler, Vantec Aero Flow cpu cooling fan, and CoolerMaster Musketeer 1.
Here are my PC spec.
Intel Pentium 4 2.4 Ghz (Socket 478) Prescott Core
Asrock P4i65G mainboard
1 GB DDR400
Maxtor 160 GB IDE hard disk
Sound Blaster Audigy Value sound card
Lite-On 18X DVD-RW
Also, I want to buy a new power supply which is CoolerMaster Extreme Power 430 Watt or PowerLogic Atrix 500 Watt if my standard power supply is not enough.I would appreciate any suggestion.
1 GB DDR400
Lite-On 18X DVD-RW
