I have a Thermalright ultra 120 extreme, and I have been noticing that my q6600 temps are starting to go up. If I have it run at stock speed (2.4 Ghz) it idles at 34c but as soon as I over clock it at all it jumps to 44c. It dose not matter at all if the clock speed is 3.0 Ghz or 3.2 Ghz, I get just about the same temps; mid to high 40c at idle and mid 50c at load. I used to idle at high 30s and low 40s when at 3.0 Ghz.
I have been reading other threads about lapping the heat-sink, or possible problems with the q6600 heating issues. I have even thought about buying a water cooling kit (150 quid max) but then after reading many... many reviews, I learned that the Thermalright ultra 120 extreme can give just about the same performance, off by a degree or two. I am going to try using AS5 tonight (I am using the stock thermal grease that the heat-sink came with).
My main question is, will I see a difference running dual fans on this heat-sink? I have the Gigabyte 3d Aurora 570 case, so room is not a problem. I am currently running with two fans but one is the stock fan from the case (which moves about 1 inch of air a minute) so I can not tell if it is helping. The other fan is the Scythe S-FLEX SFF21F. I have two 120 rear fans that blow out (78 cfm each) and then another 120mm fan (a stock case fan) on the bottom of the case to blow air from the bottom up and also help cool the x-fi fatality (the bottom fan is more for air movement so I don't get " stagnant air").
I have been looking around for a while and I can not find a definite answer to my questions. Please help me O Gurus of the computer world!
