Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > X1900XTX Problem: PSU OK? *edited*
Forum Graphic & Displays : Graphics Cards - X1900XTX Problem: PSU OK? *edited*
Hello guys I'm new to the forum. I searched for my topic but couldn't seem to find specific info for my situation.
edit*
Will this PSU push an ATI X1900XTX? It recommends 450W +30A on 12V rail. From what I can tell, this 470W PSU has 26V on a 12V rail.http://www.pcpower.com/products/vi [...] =techspecs
P4 HT @ 3.4ghz
2 GB DDR2
ATI X800XT 256MB(install ATI X1900XTX)
Audigy 2ZS
Message edited by idiotboy on 08-27-2007 at 10:53:08 PM
Sponsored Links
Oh well, I think I answered my own question searching through other forums. From what I can tell, it should run OK. Does anyone concur?
http://forums.techpowerup.com/showthread.php?t=15938
Now I just wonder why my card was resetting my monitor during the BioShock demo (+looping sound)and going black on 1024X768. It was also artifacting and texture ripping then crashing on Oblivion at 1024 X 768 + HDR. Any ideas anyone? Is the card trashed?
Reply to idiotboy
- 0 +
it may run fine, but bear in mind that its not good to run a PSU at its operational limits all the time since that will wear it out much faster
Reply to spuddyt
Thanks for the reply.......
Do you know what could make a X1900XTX run the BioShock demo perfectly for 5-10 minutes and then just crap out to a black screen when it gets up to around 90C? It has the stock cooler which I've heard is crap, but why would it artifact within 5 minutes on Oblivion with my case open? Is it a heat issue? Does it need more thermal tranfer compound on the GPU (it was barely covered and dried out/cooked in some areas.....)
BTW, I have 4 sticks of 512MB DDR2, 2 optical drives, 1 stock Dell Dimension 8400 hard drive, and an Audigy2 ZS. That's it, no other peripherals drawing power.
Message edited by idiotboy on 08-28-2007 at 12:24:24 AM
Reply to idiotboy
I have a Sapphire x1900GT in one of my systems and mine did the same thing with a corsair HX520 powersupply so i think it is just a problem with the ram on the card overheating. I installed a side case fan 90mm blowing directly onto the card and now the card only starts messing up after about 4 hours of straight gaming. Also, btw if your video card black screens, my ati always reset itself if you wait like 20 seconds and you can keep playing games(dont have to reboot). The heatsink on it is AWFUL. Im just waiting for nvidia's new cards to come out to replace it.. BTW sapphire tech support is awful.
Reply to gscrugg2
- 0 +
Don't use CCC, use tray tools to fix that crap. Control the fan speed better as the stock cooler is very effective. Maybe reseat it but pointless to go aftermarket without water.
------------------------------ Gahleon Mod
http://img340.imageshack.us/my.php [...] 023yj7.jpg
http://img340.imageshack.us/my.php [...] 068gb0.jpg
Reply to gahleon
There are 890 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
