I am buying a Q6700 Intel Retail processor and figured that I would purchase the following two items for compound and cleaner, but I want your opinion and methods.
Arctic Silver 5 Thermal Compound - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Arctic Silver ACN-60ML (2-PC-SET) Thermal material Remover & Surface Purifier - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100010
Question 1: About how many applications/reapplications can I expect from that tube of compound?
Question 2: What is the best way of cleaning the existing compound that comes on Intel retail processor heatsinks? Is it with cleaner like this or something else? Do you wear latex gloves and use a paper towel or specific type of cloth or what?
