News
Read Your Watts With A GPS Technology Power Supply
Taipei (Taiwan) - While walking the halls of the Computex trade show, we saw this interesting power supply with an integrated watt meter. Read more
Tiny power supply cranks out 120 watts
For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
CeBIT 2008: Thermaltake Offers 2kW PSU
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
OCZ rolls out 600 watt modular power supply
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Latest Reviews & Articles
GeForce 3D Vision: Gaming Goes Stereo
Do you remember the stereo glasses that were around about 10 years ago? Now that 120 Hz LCDs are starting to pop up, Nvidia is teaching an old dog some new tricks with its GeForce 3D Vision shades. Read more
AMD Phenom II X4: 45nm Benchmarked
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Best Graphics Cards For The Money: Jan. '09
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
All the Reviews & Articles
  Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Power supply Question (important, plz help)
Word :   Username :
Bottom
Author
 Thread : Power supply Question (important, plz help)
Profile: newbie
More Information
Hi all, I just bought a Thermaltake toughpower cable management (W0106) to replace an 500W Antec for my main PC. I bought it because I believe my Antec was defective in that the 12V was like 11.7V or so. I also recently bought a Thermaltake DR. Power power supply tester. It showed that the Antec was generally good, but the -5V was bad. Now the new Thermaltake reads the same. I have tried the tester on two older power supplies that showed that everything was ok. Do new power supplies have a -5V?(sorry if this is a stupid question) Please let me
know if I need to RMA. Also, there appears to be a pin missing on the main motherboard supply (no wire at all). Is there a position that is usually left out? Thanks.
Related Product
everyone should run a i7 920 at 4GHz
Profile: Ancient Poster
More Information
11.7v when does it fluxuate? 12v if steady is fine
Profile: journeyman
More Information
Some newer PSUs don't have the -5V or -12V lines as they are rarely used by todays motherboards. It's normal too that those readings are way wrong.
Profile: newbie
More Information
OK thanks for the help. The 11.7V is what is usually reads, never seen it near 12V. It works fine normally, but when I try to overclock my system becomes unstable much sooner that the limit I know it can reach (3800+ Windsor unstable at 2.4GHz). It makes sense to me that the Antec is fine normally but cannot keep the system stable enough at higher clocks. I hope the new PS is good and that I can clock higher, otherwise I have just wasted money :(
Google Ads
