Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Best non-power connector GPU?
Forum Graphic & Displays : Graphics Cards - Best non-power connector GPU?
I want to buy the best available card without a power connector due to the fact that I do not wish to upgrade my psu. I know that both the 2600xt and 8600gt do not require extra power. The 8600 seems to fair better in most benchies but I have heard that the new drivers for the 2600 really help it. Is there a better card that is dx9 maybe? I don't really have a preference ATI or NVidia. Does anyone have a suggestion between the two? Or maybe something different perhaps? I would like to stick to a $150 max budget. Thanx for replies.
Sponsored Links
Hmm....I actually heard that the 2600 was doing better than the 8600....but I could be wrong. Does anyone know the truth?
Reply to sirrobin4ever
The 2600 XT would be it, I imagine.
Can't think of anything that'd come close without a separate GPU connector.
Reply to Cleeve
There is no real "truth". The 8600 seems to be outperforming the 2600xt though in the latest benchmarks even with the newer drivers.
http://www.elitebastards.com/cms/i [...] mitstart=3
http://www.bit-tech.net/hardware/2 [...] _8600_gt/1
Those are just a few places that did tests with the newer drivers. As you can see the 2600xt performs much better than the Tom's hardware charts suggest (with the old drivers). But, the two cards are about even now. Therefore, the choice is really yours depending on what is important to you and what software comes with the individual cards that you are looking at.
Cleeve, what about the 8600gt or 8600gts? These benchmarks seem to indicate that these cards outperform the 2600xt. I'm asking because I am actually considering these cards as well for an HTPC.
Message edited by prodystopian on 08-29-2007 at 05:34:38 PM
Reply to prodystopian
I know for a fact the 8600 GTS needs a power connector though.
I believe the 8600 GT needs one, too.
This fellow asked for the "best available card without a power connector"
Reply to Cleeve
With latest drivers the 2600xt inches out the 8600gt in benchmarks. In most games the 8600gt has a couple frames on the 2600xt, though there are always some that favor ati by a couple.
My advice is go with what is on sale or you've been fanboy to, since they are really close in performance.
I am fairly sure there aren't any better DX9 cards that dont take additional power.
------------------------------ Old Enermax Case G. Skill DDR2 1000mhz 4gb(2x2gb)
PC Power & Cooling 610 Silencer EVGA 8800GT 512mb
Gigabyte P35-DS3R 2x WD1600AAJS RAID0
Intel Core 2 Duo e8400 @3.6ghz Windows Vista Premium 64bit
Reply to jwolf24601
I know the 8600gt does not need a connector and is rated for a 300W psu. Thanx for the advice all. It seems to be about what I came to. Those cards are now close to equal and outperform all similarly powered dx9 cards by some margin be it big or small.
Reply to jjknoll
There are 1333 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
