News
TSLI intros low-jitter, high-frequency PLL clock multiplier IC
TSLI today announced a very-low-jitter, high-frequency PLL clock-multiplier IC, the T98553, that is designed to replace high-cost crystal oscillators for use in serial data communications market. Read more
Overdrive: A Little Detour with Intel's Turbo Mode
Switching on the Turbo mode is required to sail around Intel's TDC and TDP safety limiters, but it also introduced some issues for the overclockers. Read more
GPS can help give early warning of tsunamis
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
PSC: DDR2 bandwagon will not arrive until 2Q 2006
Even after adjusting its DRAM output toward more DDR production, Powerchip Semiconductor Corporation (PSC) has admitted that its DDR2 output is still outpacing demand. Read more
Latest Reviews & Articles
Best Graphics Cards For The Money: Jan. '09
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
Value In SLI? GTX 260 Core 216 Vs. GTX 280
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
System Builder Marathon: Performance & Value
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
All the Reviews & Articles
  Tom's Hardware Forums » Overclocking » General Discussions » trouble with adjusting multiplier. plz help
Word :   Username :
Bottom
Author
 Thread : trouble with adjusting multiplier. plz help
Profile: newbie
More Information
I'm new to overclocking. I have an ASUS p5n32-e sli plus mobo and a e6300 conroe. I tried to oc and got it up to 2.27 ghz. I know i can go higher but I got this result only tweaking the FSB. I've tried increasing the cpu multiplier from 7 to 8 and 7 to 9 but after choosing save and exit the multiplier goes back to 7. Has anyone else had this problem or know how to fix it? I would greatly appreciate any suggestions/help.
Related Product
If you choke a Smurf, what colour does it turn?
Profile: newbie
More Information
I believe that the CPU multiplier on all the mid - low range Conroes are actually locked, and that it can only be changed on the extreme models.
I may be wrong though.
Cheers
Plays with his WEI
Profile: Honorary Poster
More Information
You have to have an Intel "Extreme" processor to get an unlocked CPU multiplier. You will be able to lower the multi on a non-Extreme proc, but never raise it.
The more I read the forums, the more I feel that a number of individuals would be well served by skipping their next GPU purchase in favor of a little "Stress Relief" from the local Working Girls
Profile: newbie
More Information
OK, thanks for that info. That bums me out a bit. Are there any other things I can do to make this thing go faster? I've heard of people running their e6300 at 3 ghz. Is that all just by changing the fsb?
Message edited by vinceak04 on 10-17-2007 at 07:45:45 PM
Plays with his WEI
More Information
Yes - The main overclocking tool you have is increasing your FSB. Now, a 1.86 to 3Ghz is a pretty steep overclock - With a 7 multi, you'd need to run your FSB at 430Mhz: That's going from 1066 to 1720Mhz. You can do that, but at that large a jump you'd:
(1) Certainly have to bump the voltage to your CPU some - More volts = more heat. Is your cooling up to the job?
(2) Likely have to bump chipset voltages as well: 266 to 430 is a pretty healthy jump. My board is going 400 on Auto, but I'm pretty sure that's about as much as it'd go without bumping the chipset some. Again: More volts = more heat, and do you have good cooling?
(3) Nearly all Intel boards link memory and FSB speeds. You'll have to watch out you don't clock your memory too hard by accident. Not too big a deal, but you'll have to pay attention. At a 430 FSB, you could mildly overclock DDR2-800 RAM at 1:1 and end up with an 860 clock there. Should be fine given any decent DDR2-800 RAM.
By way of (vague) comparison: I have my Q sitting on an 8 multi/400Mhz FSB with my memory running at 800. Runs very nicely, CPU is fine, chipset a bit warmer, at basically stock voltages. A similar setup would have your chip running at 2.8Ghz, presuming you leave the multi at 7. I don't know where you are now, but I'd pick an intermediate step before jumping to 400, for sure...
By way of disclaimer: My Mobo/chipset/proc/memory are all different from yours. Therefore your mileage *will* vary.
Profile: newbie
More Information
Thanks for the tips. My cpu is running at about 42 C right now so i think the the cooling is ok as long as i don't go to high. i'll be happy with about 2.5 ghz out of this thing. What is too hot for the temp on the cpu? How hot can i get it without worrying about it?
Message edited by vinceak04 on 10-18-2007 at 12:08:13 AM
Plays with his WEI
More Information
Is that 42 under load? or Idle? How fast do you have it going now? What are you using to measure the temps? I ask because 42 idle is kind of high, 42 under a heavy load is wonderfully low, but that's a reasonable temp while playing a game...
When you're really beating the snot out of the computer with Orthos or Prime 95 - (links available in the Overclocking Thread) - I'm comfortable seeing temps in the 60's, as long as they're stable over the course of the test. If you're closing on, or exceeding, 70 degrees C then you need to look at your cooling/voltages and see what you can do to make it better.
Mostly, as long as you ditch the stock Heat Sink/Fan for a high quality cooler then you should be good as long as it's installed properly.
Go through the "How To Overclock a C2D..." sticky. Read through it a couple times. It's an excellent general guide.
Profile: newbie
More Information
Its actually closer to about 40 C idle. When playing games it jumps up to around 50 I believe. I use CoreTemp to measure the temp. This is with my E6300 @ 2.45 ghz. Thanks for the help :)
Google Ads
