News
Tclink demonstrates car-radiator based cooling system
If regular computer cooling system aren't just enough, Tclink/Ebiz offers a liquid cooling system that uses an "automotive" radiator. Read more
IBM promises cooler chips with capillary-action and water jets
IBM's Zurich labs have developed a new heatsink and water-cooling that promises to cool chips up to six times better than conventional air cooling. The heatsink contains tiny channels similar to the capillaries you would see in tree leaves and in human circulator systems. The channels allow either water or heatsink compound to spread more uniformly and thereby dissipate more heat. Read more
CeBIT 2008: RAM Watercooling By Gigabyte
Gigabyte, more commonly known for its motherboards and graphics cards, is presenting a water cooling solution for RAM modules, dubbed Cool Rain. Read more
OCZ's 1150 MHz memory integrates liquid cooling
If you enjoy squeezing every bit of performance out of your computer, then you are used to dealing with large and potent cooling systems already. Read more
Latest Reviews & Articles
GeForce 3D Vision: Gaming Goes Stereo
Do you remember the stereo glasses that were around about 10 years ago? Now that 120 Hz LCDs are starting to pop up, Nvidia is teaching an old dog some new tricks with its GeForce 3D Vision shades. Read more
AMD Phenom II X4: 45nm Benchmarked
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Best Graphics Cards For The Money: Jan. '09
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
All the Reviews & Articles
  Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » Recommendation about good water cooling stuffs
Word :   Username :
Bottom
Author
 Thread : Recommendation about good water cooling stuffs
Profile: stranger
More Information
Hey Guys!
I hope you'll help me..
I live in Israel as you know Israel is not the place for OVERCLOCKED or for overclocking stuffs and those stuffs cost much more than every other country.
I'm looking for CPU and GPU water cooling system not in one package I mean I want you to recommend me about parts, good parts that will be used for long time and these stuffs wont cost much.
I wish you guys will help me THANKS!
Related Product
Profile: stranger
More Information
Cant u guys fkin answer :S?
Whe..whe...Where am I????
Profile: old hand
More Information
Being rude won't get a response any faster. Don't be rude.
As to your original question, there are MANY different ways to go with water cooling, and for us to blankly recommend parts is not a good way to go. You have not told us ANYTHING regarding what kind of computer you are attempting to water cool, nor have you told us about your budget, the environment this computer will be in, or the locations from which you will be purchasing. So, effectively, since you did not give us any information, we can not give you any information.
The best thing you can do is research yourself. Try using Google and read up on forums. After that, come back and ask more specific questions. Just be sure to include your system specs and other stuff when you do.
Good luck.
I know everyone has a right to be stupid sometimes, but some people abuse it.
+5 Victim
I need COFFEE!
Profile: Forum Resident
More Information
I'll add a few bits to this, maybe they'll help.
Okay - you're in a hot country, so straight-up watercooling isn't going to give you as good results as you'd expect - it goes from 5ºC above ambient to about 25ºC above. I'd personally suggest a beefy external setup, like a Zalman Reserator or similar.
+15 Wingding/+20 DingWing Approval +14 Observation +12 Science Geek +10 Unforgiving.OT/Messiah/Waterwalk +5 Inquisition/Human Sacrifice/Godly Wrath/Scouse Approval +3 Reverse Stuffing +1 Ranting/Common Sense/Literacy Standards/Hindsight
Google Ads
