Tom's Hardware Forums » CPU & Components » CPUs » 6750 not running at 2.66, running slower
Add a reply
 Word :   Username :
Bottom
Author
 Thread : 6750 not running at 2.66, running slower
Profile: stranger
More Information
I have a 6750, never been touched by overclocking and i have a gigabyte p35-dsr mobo...
when i run CPU Z, the clock speed shows at 2000, i thought it would be running at like 2660 or 2666, its running considerably slower than what it should....
Its weird on my XFX video card, its only showing it has 256 instead of 320 on my 8800 GTS....
Im also running Vista Ultimate 32bit in case that helps at all... still trying to figure out all the things in windows and how it works
If anyone knows the answers to any of these.. please let me know
Related Pr oduct
Profile: Honorary Poster
More Information
Intel SpeedStep...Intel SpeedStep...
Profile: Faithful Poster
More Information
Yes he is right, when your systems at idle this is called SpeedStep. Its shutting down parts of the processer that are not active, effectively reducing power consumption.
Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Profile: addict
More Information
I think it's funny how often this question come up.... really. It's been asked tons of times. I jus think it's slightly amusing.
But yeah, systemlord is right. It doesn't affect performance at all. Once the extra power is needed, it puts the speed back to where it should be.
And I'm not really sure what's up with your videocard. I'm sure it still uses all of the RAM, even if it does not report it...
PENS.. forgot the i...
Profile: old hand
More Information
sorry, but somehow i doubt it is speedstep, speedstep drops the multi down to 6x, 6x266=1596 (approx 1.6ghz), he says his is at 2ghz
-"From whence you came you shall remain, until you are complete again!"
Peter Mitchell
LANiMAL
Profile: member
More Information
He can check it in bios, also he cud post the fsb and multi to make sure!
Profile: member
More Information
Actually rammedstein it's an e6750 so it runs at 333 fsb.. so that's 333x6 which 1.99 Ghz. It's probably Speedstep.
Or it could be running at 266 fsb if you didnt update your bios to F2.
Check the multiplier, if it is 8 and the cpu is running at 2 Ghz (266x8) then you will need to update your bios to F2 version or greater to make it run at 333 fsb, if the multiplier is 6 at the same speed (333x6) then it's definately speedstep.
Message edited by bash007 on 08-19-2007 at 01:23:22 PM
Profile: old hand
More Information
my bad, i didnt see the 50 so i instantly though 6700
Peter Mitchell
More Information
MrsBytch wrote :
Dont you people ever read your manuals???
Theres some idiot on here every day asking why his cpu doesnt run the right speed......geeeesh, read your friggin manual!!
While this is very true, for me once I start building and have the parts in my hand you just try and stop me. :D We have all been there where we forget the little things because its so exciting. I for one didn't read the white book that came with my CPU either.
Profile: stranger
More Information
There is nothing in the manual about this.. if there is... i totally missed it... but if Mrs Bytch can find it, i will think he or she is a god, but if she or he cant... then he can shut up and suck it.
For everyone else... thanks for the info... i guess ill have to look and see what my bios is set up at. I guess i never thought about the speedstep thing.
Add a reply
Google Ads
