Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Power adapter question for the x1950Pro
Forum Graphic & Displays : Graphics Cards - Power adapter question for the x1950Pro
I have just one last question before making a purchase I need some help with. I posted this within another thread but it got buried.
I want to get this HIS X1950Pro: http://www.newegg.com/Product/Prod [...] 6814161082
Looking at the pic of the back of this AGP card, I see it needs a 6 pin power plug. I have a 4 pin adapter coming off my power supply. It currently powers my x850xt. The HIS product ships with a dual 4-pin to 6-pin power cable (see pic in the link above that shows the adapter). Will this work to power it based off what I have? Do I just plug one of the two 4pin ends of the adapter into the end of my existing power adapter and the 6 pin end into the card? I am assuming I would just leave the other 4 pin adapter alone and unused?
Thanks!
Sponsored Links
How well it works depends if you have a decent PSU or not.
But yes, if it has a 4-to-6 pin adapter with it, it will connect fine.
Reply to Cleeve
whew...thanks Cleeve
Reply to EF77
There are 868 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
