If the eXtreme Power Supply Calc says it will work why doesn't it?
Last response: in Components
Related ressources
- Power supply calc - somethings not right - Forum
- Can anyone help me connect my GTX 460 to power supply ? - Forum
- Power Supply Question - Forum
- External Power Supply ? - Forum
- Power supply newb - Forum
Related ressources:
- ForumPSU Calc ***Release Candidate*** v0.99
- ForumNeed a bigger power supply ?
- ForumThe Power Supply Adventures - We never can tell, can we?
- ForumPSU Calc
- ForumExtreme Power Supply Calculator Crazy???
- ForumPower Supply doesnt have -5V, Does motherboard need?
- ForumWhich power supply should I get
- ForumPower Supply Requirment Question
- ForumWhy do PSU calculator lie? Help!
- ForumBest power supply
- ForumCould a Rosewill 550 watt power supply handle this?
- ForumWill this setup run skyrim at ultra?
- ForumHow to turn a power supply "hard" on without motherboard?
- Forumfaint squealing sound pc power and cooling silence 750 quad
- Forumwhat power supply should i get
- More resources
Read discussions in other Components categories
. Try putting the 7600gt back in and see if it does this. If it does not then i would put my money on the PSU. If you tell me ruffly bout how much you want to spend on a PSU i can help you. With you upgrading soon unless you want to keep the PSU for your new build. Also you can refer to this LINK to find out more about PSU's what you might need and such.
