Tom's Hardware > Forum > Graphic & Displays > ATI > Radeon X1650 - secondary monitor limited to 1024x768
Forum Graphic & Displays : ATI - Radeon X1650 - secondary monitor limited to 1024x768
I have a Radeon XS1650 with 256MB memory
I have an LCD monitor on the main VGA port running at 1400x1050 and I have a Iiyama Visionmaster PRO400 CRT monitor on the DVI port (using an adapter that came with the card). The monitor is setup with the correct driver in WIndows XP.
If I set the resolution of the secondary monitor to > 1024 x 768 it just gives me a scrollable desktop of whatever size I specify, as tho it thinks the monitor can only support 1024x768.
Sponsored Links
OK, I solved this one literally minutes after I posted, having struggled with it for the last few weeks.
Oh and the card is a X1650.
Got the Iiyama monitor driver installed.
Loaded up the ATI catalyst control centre
properties of monitor number 2
set max resolution to 1600x1400
all ok after doing this
sorry.
at least this is here for anyone else with the same problem
Reply to fpdave
There are 1176 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
